Question about Dishwashers
GET 0E CODE SHOWING ON MY LG DISHWASHER - Dishwashers
    Problem Solver:
  • 9 Answers
Ok i have this problem with my dishwasher although i have pushed the microswitch in somehow the problem keeps coming back. after just pushing on the microswitch with a screwdriver it only temporary fixes it. Also the switch doesnt appear to have come out. i can hear a click when pushing on it though. any suggestions. The microswitch was replaced at an appliance repair shop
Posted on Oct 02, 2011
    President:
  • 1,197 Answers
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
if that doesnt help you.....
the problem IS NOT necessarily a blocked drain hose or the drain pump it could be the thermostat micro switch!!! the thermostat is located at the rear of the right bottom side of the dishwasher(held by oval nylon plastic housing). Turn the machine off. remove the right side panel.(remove top {2screws in lid at back}, remove right panel screws {2 behind door, 3 bottom back panel, 2 behind panel below door {pull panel out from top [no screws pushes in & out of place]}. Locate oval nylon/plastic shape located as above - micro-switch is in the middle (3 wire connectors in 1 block) thermostat is 2 connectors ( 1 each side of micro-switch). use screwdriver to push thermostat back into the nylon housing on both sides (it has worked its way out a bit over time and stops the micro-switch working). Reassemble and dishwasher starts to work again!!!!
Posted on Aug 28, 2010
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
May 14, 2010 | Dishwashers
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher Model: LDS5811ST getting error code: 0E
OE is a drainage problem...check for twist or obstruction in drain hose .. make sure filter screen is clear... Hope this helps..
Sep 17, 2008 | LG Dishwashers
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
Owen Barnes
