Question about Linksys EtherFast Cable/DSL Router
My new linksys router BEFS41 can't connect to a cable modem that is working. when computer is plugged direct to cable modem it works. Why can't it connect to the router?
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Aug 28, 2010
I just switched from cable modem to dsl modem..dsl modem gets on the internet when connected directly to computer..once connected to router doesnt connect to internet
Your new ISP is DSL. the router was working before with the cable modem. The settings for the cable and DSL ISP are different. Now your computer is working when you connect it directly to the DSL modem. that means the modem is working.
The DSL modem works on 2 different modes.
You will need to check which mode is your modem working on and according to the settings of your modem you will need to set up the router.
To change the settings of the router, you will need to open the set up page of the router.
Click Here for more information about the router set up.
Feb 20, 2010 | Linksys WRT160N Wireless Router
Hi, I'm an idiot! PLEASE HELP
you may be suffering from mixed Cat 5 and Cat 6 cabling.
The wiring is slightly different and they don't work well when mixed in routers and modems etc. One or the other will work , but when they're mixed it'll do what you have going on here...
I would recommend wiring everything with cat 6 ethernet cabling. Look on your cable and you will find the labeling on the outer casing.
Sep 20, 2009 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Zhone linksys router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
i have read the same problem on the supportrix forum and you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 06, 2008 | Zhone (6218-I2-200) Router
Hooking up rounter to cox cable
hello!
-- is the router working fine before or is it a brand new router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
I just got a Linksys Router and im having trouble connecting to the internet?
hello!
note:
May 18, 2008 | Linksys Wireless-G WRT54G Router
No connection
hello!
May 12, 2008 | Linksys Wireless-G WRT54G Router
Installation
hello!
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
May 07, 2008 | Linksys Wireless-G Broadband Router
Unable to get a IP address to my workstation at home,
just wanted to clarify
* have you tried connecting desktop and laptop straight to the router? (because with your statement you only connect both computers straight to the modem and only the laptop works fine).
Apr 29, 2008 | Linksys (RT31P2) Router
Linksys EtherFast Cable/DSL Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
