Question about Disney 13" TV
Hello! I'm trying to program cable but it's not connecting. The skip channel keep coming on.
    President:
  • 1,284 Answers
If you are on Comcast cable there are very few stations that will program on your analog tuner. I believe it goes as high as channel 34. Past that you need to get a DTA or digital television adapter from Comcast. You get a total of 2 for free.
Posted on Aug 28, 2010
How do i get reception with only a cable connection...no box. i don't know what settings to have the tv on.
In the main menu select "CABLE" AND NOT AIR.
With the cable connected to the coax fitting then turn set on and look for AUTO PROGRAM------engage that and the set will scan thru all the available channels.
If it misses any you can with the remote direct enter a channel and in the main menu "add" it to the up down memory.
It is also helpful to "skip" out channels you do not want in the up/down memory-----this is in main menu also.
I usually skip out the Golf channel and others I never watch.
Let me know if you have questions.
Dec 07, 2011 | Toshiba 51H84 51" Rear Projection...
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
I accidentally hit the menu button on my tv and seem to have reset something. It goes from Channel 126 directly to Channel 24 and will not set to channel 3, which is the only one that works with my cable
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
Oct 16, 2010 | JVC AV-27530 27" TV
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
Oct 01, 2008 | Emerson EWF2004 20" TV
MGA 1989 19inch standard tv. - model #CS-1946R
Try this. I the control box under screen (with a door) is a botton TV/CABLE.HCR. Try pressing this button to get more channels. Mine was on TV, but needed CABLE. Best wishes.
Dec 06, 2007 | Televison & Video
Disney 13" TV Logo
42 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
