Question about Dell Dimension 2400 PC Desktop
WHEN TRY TO GO ON LINE WARNING SIGN KEEP COMMING AND SAY TASK CAN NOT BE EXECUTED THAT I NEED TO BUY PROTECTION FROM THEM,NO WAY TO GO IN LINE NO MATTER WHAT I DO. E-MAIL------AMOREMIO112898@YAHOO.COM
  • 1,472 Answers
Amoremio1128
It sounds like you have picked up a virus on your computer. If you can not get the computer online to download your updated anti-virus DEF files then you are going to need to pull the hard drive from the system to clean it with another computer or backup you files then wipe the computer and reinstall the OS.
If you have access to another computer and need help with a process to pull the hard drive let me know or any other questions you may have.
Issken
http://www.fixya.com/users/issken
Posted on Aug 28, 2010
I opened a email for someone, on my browser, at gmai now when i try to open my own email, his keep comming up
sign out from that account then you will be able to sign in into your account by entering your email id and password.
Jan 26, 2014 | gmail.com Computers & Internet
How to keep the heater going
sounds like a faulty heater thermal protection device or over current trip. you need to refer to a qualified electrician or replace. The safety cut outs should not be defeated as they protect you from fire.
Dec 05, 2013 | Heating & Cooling
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
The calender key on my nokia e52 keeps on pressing it self. I change its setting on the one touch keys setting to none but now i keep on hearing beeping sounds as if a key on the keypad it been pressed,...
If the key remains pressed, there are 2 solutions:
1) try to use a very little amount of fine oil to make the button move easier. Warning: This is a service task, so it is not a good idea to do it yourself. Take the phone to a mobile service.
2) Change the keyboard panel to a new one. This is also a service task.
The bottom line is, take the phone to a mobile service.
Apr 16, 2011 | Nokia E52 Smartphone
My calculator is only graphing one function at a time, how do i graph multiple funtions. i try highlighting both funtions but when i select one then the other one, only one stays highlighted
Here it is.
When you enter a function you should press [ENTER] to validate. At the same time, the cursor moves to the next line. Verify that the = sign on the equation already entered is still highlighted.
If for some reason the = sign of an equation is no longer highlighted, use arrow keys to move cursor on the = sign and press [ENTER].
If only one = sign remains highlighted and all others are not, then in all probability the application Transfrm has been executed before and is still lingering in RAM. When in RAM, it takes over the graphing capabilities of the native OS. This prevents you from drawing more than one graph.You must unload it from memory.
  1. Press the [APPS] key.
  2. Scroll down to the line that shows Transfrm.
  3. Highlight it and press [ENTER].
  4. In following screen you are invited to Uninstall or continue.
  5. Press the number to the left of Uninstall. Validate if need be.
  6. Return to the Y= editor to type in functions to graph.
Sep 24, 2010 | Texas Instruments TI-84 Plus Calculator
I can't make my calculator to graph two equations
The following should help draw several graphs.
Only the first graph is shown
Sep 23, 2010 | Texas Instruments TI-84 Plus Calculator
Write protection in N70 nokia mobile MMC card
there are many things you can do to remove write protection but you have to give rating to me. Here is the first one 1.)go to MY COMPUTER 2.)right click on MMC drive 3.)click on eject. 4.)remove MMC form card reader 5.)again put it back (if at once it didn't worked try again step{2,3,4}
second method is: sometimes your USB port locks it try some other USB port & then put the MMC in memory card. pls rate me thank you
Feb 14, 2009 | Nokia N72 Cellular Phone
Model MX6441 i have antivirus protection that keeps popping up if i do what it says then it says the cost is 49.96. I do not want to pay this for a viris protection. I have another one how do I get this...
hi anna4042, are you referring to your antivirus popping up messages that you need to buy the product? or a notification that you have a virus on your pc and you need to remove it by purchasing the said product? whats MX6441
Jun 03, 2008 | Gateway Computers & Internet
Dell Dimension 2400 PC Desktop Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
