Question about Garden
RE: MTD trimmer YM1500, 31 cc motor. Won't run without the check lever near full on. Fresh gas, mixed 1 gal to 3.2 oz 2-cycle oil. Found & tightened loosescrew on throttle butterfly valve, and loose screw on reed valve retainer. Replaced a faulty magneto module. Air filter & spark arrester screen are clean. Carb insides LOOK clean. Is there any adjustment other than the idle speed screw? Carb # 753-47807.
    President:
  • 1,545 Answers
Most carbs have a H (running) and L (idle) mixture screws on them, but the newer ones are getting away from that somehwhat and some aren't adjustable. I am including a tech guide for carb adjustment for a Zama carb. All diaghram carbs are similar.
http://www.zamacarb.com/tipspage.html
Posted on Aug 29, 2010
I have 1/2 can of 8 oz oil per 1 gal gas. I need to change it to 2.6 oz oil to 1 gal for a weedeater. How much gas should I add to what I have to get the proper mix of 2.6 oz to 1 gal gas?
you buy a really small measuring cup . or guess at it .1/2 can will be 4 oz half is 2 so it is someplace between the 2 of them .
Oct 16, 2016 | Garden
How do i mix the gas/oil on a 25 cc 2 cycle craftsman weed eater
The specs say 40:1 so 3 - 3 1/2 OZ of 2 cycle oil in a gallon of gas.
May 10, 2014 | Craftsman 25cc Gas Line Trimmer
Ounces per gallon 31 cc engine
If this is a 2-cycle engine, Ryboi are 50:1 check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 50:1 ratio (1 gal.) Gas to 2.5 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Oct 07, 2013 | Ryobi Backpack Blower 25.4cc
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
What is the problem when my 27cc craftsman weed wacker starts but doesnt stay running
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to clean or replace carburetor.
May 29, 2012 | Craftsman 27cc 2 Cycle Crank Straight...
Unit not starting
Dec 06, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
My weedWacker don't star I change the spark nothingh happen
Aug 19, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
What type of fuel mixture do I use for 20760 Homelite gas trimmer?
Most likely not the answer you are looking for but here is a shot:
Pick up a bottle of the Echo brand 2-cycle oil. It will say "Extended Life" on the labeling. This is meant to run in Echo products, but it is a very FINE and well engineered oil. Mix it according to label directions for 50:1 ratios. (2.6 Oz. to 1 Gal. Gasoline)
When mixed at this ratio it provides MORE than adequate engine protection for ALL 2-Cycle engines, including those that run in 40, and 30:1 ratios.
I mix one 2-cycle tank to label instructions on the Echo oil for 50:1. It handily runs in my Echo chainsaws, non-echo trimmer, Poulan Pro leaf blower, etc. They all run different ratios, but THRIVE on the Echo mix without as much oily residue and smoke to boot!
CAUTION: I do not know of ANY OTHER MAKE of 2-cycle oil that CAN DO THIS *SAFELY*.
Remember:
Always mix your 2-cycle fuel starting with *fresh* gas.
Mix only that which you can use in 30 days.
Use 89 Octane fuel to make your mix in small piston 2-cycle engines.
Clean and re-oil intake filters @ every 10 hrs. operation time. Check and re-gap your plug when you service your filter!
DRAIN unused fuel from tank back into gas mix container. Restart and let engine idle to run any remaining fuel out of engine and carb. Storing fuel in ANY 2-cycle longer than two weeks is going to gum them up and nothing short of a carb rebuild will get them sputtering back to life again!
May 08, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
