Question about Porter Cable 7800 Drywall Sander With Dust Collection
When I push the sander on the wall it stops spinning and starts clicking
  • 1,040 Answers
The best way to sand drywall is to use a pole sander (manually). You can pick them up for about $20.
This particular machine tends to leave grooves in the drywall compound if you are not familiar with how to use it.
If you should have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
Thanks,
Jim
Posted on Sep 09, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Did this, or would it have help you to solve the problem. Please rate my answer if so.
    Thanks!
    Jim
My hitachi sv13ya done? My sander turn on spins but as soon as i try to sand it stops spinning. It has no torque. Is it done or can it be fixed
There is a ball bearing bearing on position 29 that is dirty replace it or remove and clean it open the sealings with a very little thin screwdriver solvent it out and re grease it and close the sealings again.
Hitachi SV13YA 5 Variable Speed Random Orbit Finishing Sander Parts
Sep 23, 2015 | Sander Tools & Hardware - Others
Please help me to understand a faulty motor
If you go on a Bosch factory web site you should be able to enter your model and down load a parts list. From that you will see that the motor drive an eccentric dog that causes the plate to jitterbug. If you kept the original paperwork you will have had this with it. All Bosch units come with warranty and parts list. Look up your nearest Bosch tools agent, see if he'll strip it if you can't and determine what's needed. You may find its easier and more cost effective to shop around online for a special offer and buy a new one. Not very green I know but may be more practical.
Jul 21, 2014 | Bosch Pex 400 AE Expert 350 W Random...
On the festool dry wall sander the machine starts then stops the red light stays on I have replaced brushes any ideas
modul itself is the smallest chance but the switch to the electric field contacts one of them on the statorfield power cable break (only one fase on machine ) armature/commutator and its stops at a broken collector on a little obliquity brushholder ???
Jan 05, 2014 | Festool LHS225 Planex Modular Drywall...
Sander doesn't spin
YOUR BALLBEARING where the disk is on mounted is the right bearing that have the problem for shure it is full of dust or completely dry it will not turn anymore SIMPLY TO CONTROL IF YOU MOVE YOUR DISK NOW ON YOUR MACHINE YOUR ARMATURE TURNS DIRECTLY WITH THE DISK thats not good the armature must stand still , replace the ballbearing or remove it and open it with a very little sharp screwdriver on the both sides solvent it out try to turn the bearing carefully until its turns without problems dry it or blow it out with a compressor and if its dry lubricate with ballbearing grease close it again and mount it again
Nov 13, 2013 | Metabo SXE450 00458 6'' Random Orbit...
Black & Decker Belt Sander suddenly stopped working.
Probably not.
It may have just had a part break inside, like the on-off switch, or one of the wires to one of the brushes, etc., etc.
I buy these regularly, and they are inexpensive, which also means they are made of inexpensive ( cheap) parts.
It wouldn't hurt to take it apart, knowing it may not be repairable. Sometimes parts are available on-line.
Be blessed.
Mar 10, 2013 | Black & Decker BR318 3" x 18" Belt Sander
How do I remove E E Code
Try unplugging it, and then replug it into the wall socket and turn it on.
Sep 19, 2012 | Black & Decker Black And Decker Cyclone 4...
My porter cable sander starts then stops and now it wont start at all thank you
If it is not the plug in the wall socket being loose, then the most common is the motor contact brushes.
Mar 12, 2011 | Porter Cable Palm Grip R.O.S. With Kit Box...
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
Disc pad stops
It could either be that the brushes partially burned I would check to make sure your brushes are in good shape and take it out of the helpers pay ;)
Nov 06, 2008 | Porter Cable 332K Quicksand Random Orbit...
Porter Cable 7800 Drywall Sander With Dust Collection Logo
135 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
