Question about Samsung Refrigerators
The seperating bar is hot - Samsung Refrigerators
  • 139 Answers
Their is a heat strip under this bar to stop condensation ..in hot humid weather..their should be a switch in frig for this heat strip ..on to reduse exter. moisture //on in summer off in winter or off if you have central a/c ../joe/
Posted on Aug 28, 2010
WHEN SET FOR HOT WATER RADIATORS ARE HEATING ALSO
there should be a seperate adjustment for hot water and for central heating, if they are on timer that is. If you are switching on at the boiler / combi check for the seperate switches
Jun 08, 2016 | Cars & Trucks
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
Feb 26, 2012 | Televison & Video
Have a new samsung phone. trying to write a message and cant find the space bar to seperate the words
Hello
when you get to your message and you have typed a letter the button you would use to seperate the words is the # button.The # button stands as your space bar.
GOODLUCK
Jul 03, 2010 | Samsung SCH-U450 Cell Phone
Torsion bar banging sounds when traveling on moderately rough roads.
The torsion bars have rubber insulators, or mounts that are located on the frame crossmember. These mounts are prone to seperate or break.
Good luck
Mar 12, 2010 | 2002 Chevrolet S-10
The seperator between my Hot Point side-by-side, the piece of metal that is inside the refrigerator that seperates the fridg. and freezer is very hot, where the doors close on...why???
this is usually an indication that the condensor an has stopped working and is unable to cool the condensor lines and this heat is being transfered to the rest of the fridge .
Feb 02, 2010 | Refrigerators
Does it run on 30 weight oil or a mixture of gas and oil?
It is an electric chainsaw, you need bar oil. Your manual says use 30 weight non-detergent. That is what bar oil is, with a few additives to help keep it on the bar and chain. It can be purchased at home centers and hardware stores and is less expensive than most motor oils. HTH
Lou
Nov 13, 2009 | Desa International Remington 12" Electric...
How do i seperate passenger side cv axle from transmission
Once you seperate the axel from the wheel hub you should be able to use a small pry bar or screw driver to help seperate the shaft from the tranny. Once drawn out a slight tug should take it out all of the way. Be careful not to seperate the CV joint.
The attached may help too.
http://www.youtube.com/watch?v=OTDblxDpyRI
I hope this may have helped,
Tom
Oct 14, 2009 | 1997 Mitsubishi Galant
The beater bar won't turn - the belt is fine. Any other suggestions?
Can you pull the bar and check the end caps to be sure they spin seperate of the bar? Also look at the wheel from the motor that turns the belt. This may be spinning on the shaft which could be caused by a broken pin.
Jun 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Aug 14, 2008 | Hunter Ceiling Fan Light Switch Control
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
