Question about Toshiba 32A33 32" TV
Toshiba tv on/off switch has burnt .Is it able to replace.
    President:
  • 1,284 Answers
If the push switch is bad then you will need part number 23344507 the same part number is used for POWER, VOL, MENU etc... So to verify you could swap one of the others to the power.
Posted on Aug 28, 2010
How to change the lamp on a toshiba led 55inch
Are you replacing the backlight and the backlight driver? Both should be done, the connections get burnt. It is almost cheaper to just buy a new LED TV, far superior picture and all around performance.
Sep 07, 2016 | Toshiba Televison & Video
Toshiba TV wont switch on
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 01, 2017 | Toshiba 37WLT58 37 in. LCD TV
Does not turn on and indicator of power light just flashes at you
Most likely a burnt out bulb, contact Toshiba for a replacement for your tv
Feb 28, 2011 | Toshiba Televison & Video
I have toshiba tv which was working nearly 10 year without any problem but now tv is not working if we switch on it power supply to the tv is proper but tv is not working please come an see this...
Hi
Firstly and would remove all the leads from your TV and check them. .
WHAT I RALLY THINK IS THE PROBLEM IS THE PICTURE TUBE BURNT OUT IF YOU HEAR IT CLICK ON WHEN YOU HIT THE POWER BUTTON BUT YOU SEE NO PICTURE OR HEAR IT CLICK BACK OFF THEN YOUR PICTURE TUBE IS BURNT OUT
If it is still failing then there is a strong possibility that your Eeprom IC on your main AV Board is corrupt and needs replacing. This should only be attempted if you have good soldering skills as they are Surface mounted and very small.
My advise if your skills are not that good is just to replace the main AV board (Scart Board) these usually sell for around £50 but WILL solve your problem.
I have gone trough everything i know here that would cure the fault, most times one of the above three will cure this, but im afraid other times its just time for a new AV board.
Hope iv helped some people out here.
Any comments or thumbs up appreciated.
Nov 23, 2010 | Toshiba Televison & Video
No picture just clicking noise
bulbs burnt right out. old old old tv. needs to be replaced. it would be cheaper to grab another tv then to try and repair this.
Feb 16, 2010 | Toshiba 27A51 27" TV
Burnt Resistor
There are LIKELY other bad components that caused this. Resistors USUALLY don't fail on their own.
Jan 30, 2010 | Toshiba 32A33 32" TV
Turned on and smoke
Is the burnt circuit on the motherboard or the power switch circuit board that plugs into the motherboard? Big difference, if the burnt circuit is on the motherboard then yes the motherboard is done and will have to be replaced, but if it's just the power switch circuit bard, then this is replaceable.
Aug 28, 2008 | Toshiba Satellite A105-S4334 Notebook
Power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Aug 09, 2008 | Toshiba 32A43 32" TV
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 32A33 32" TV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
