Question about Sharp VL-A45 8mm Analog Camcorder
For Sharp Viewcam VL-A45, the output cable has only two composite cables (white & yellow) instead of three (red, white & yellow). So would that work as far as transfering to a DVD recorder?
SOURCE: Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Posted on Oct 02, 2008
SOURCE: Drivers for Sharp Viewcam VL-Z3E
USB driver for Sharp VL-Z800
Posted on Oct 07, 2008
please send to me driver for Mini dv sharp viewcam VL-Z1
Posted on Oct 16, 2008
SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Posted on Nov 19, 2008
  • 9 Answers
SOURCE: Sharp + VL-Z7 + Software
Please go to: http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=979&view=catalog/ss_items they have the CD-ROM for $ 11.00. Good luck
Posted on Apr 20, 2009
How do I connect my sharp camcorder model VL-E650U to my Samsung tv series 6 630 lcd tv to view the 8mm videos on my TV screen?
You will have to use AV cables and an adapter. The adapter looks like a scart cable connector, it is that shape , and it has 3 inputs
one red one white and one yellow. It should fit in a spare scart socket on the tv and the cables should attach to the camcorder.
Just program the video to a particular channel, you may have to consult your owners documentation to discover how this is done. Go to the channel, insert the tape and press play.
Jun 25, 2015 | Samsung Video Cameras
How can i connect a video camera to play through tv. my camera cables are red-white-and yellow. tv. is white-red- green-green-and red.
Your camera has three cables, red and white for stereo audio, and yellow for what is called composite video. Composite video puts the three color signals into one composite signal. Your TV sounds like it has a component video connection, which wants all three color video signals separated onto three plugs. They are usually color coded green, blue, red. Not sure if you mistook a blue outlet for green..... In any case, on my TV, it will allow me to connect a yellow composite signal to the green component jack, the first (leftmost) of the three component video jacks. Not sure if your TV will work this way, but it is worth a try. Otherwise, you can look up accessories for your video camera and see if it can output true component video and stereo audio, but I tend to doubt it will.
Aug 27, 2014 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
What are the red yellow and white cords for i have a xbox
The side with 3 RCA jacks, red, white, and yellow, is for connecting the USB to a composite video cable. The black connects to an S-video cable; you would still use the red and white plugs to carry the audio. At least the older XBox's had composite video outputs; you just need the composite video cable (which you may have as they came with many video devices (VCRs, DVD players, video cameras).)
If you need to connect this Video capture device to another type of output, you will need a converter. Component to composite video would be one option. However, you will have signal loss with any converter.
I hope this helps.
(Composite video cables: yellow carries video, red and white connectors carry the Right and Left audio)
Nov 22, 2010 | Sabrent USB-AVCPT Video Capture
The only connections that work are the component cables(color stream, RGB-Red, Green, Blue) which I understand is a better quality picture but the connections for my DVD player are RCA (Composite - Red,...
You'll need a DVD player that has component outputs. The composite carries the entire video information, while the component sends the three different color signals separately. The red and white cables are output cables. No all DVD players have the component outputs.
Jan 27, 2010 | Hitachi 43FDX01B TV
Sharp VL A10 audio video cable
Is the both ends of the cable color red, yellow and white.
You can buy it in any electronics center or store. just tell RCA Cable.
melnavz
Aug 24, 2008 | Sharp Viewcam VL-A10U Camcorder
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Transferring to DVD?
Maybe when you play the 8mm tape on the TV and have DVD/TV recorder hook up to the TV.
Oct 23, 2007 | Sharp Viewcam VL-A111U Camcorder
Sharp VL-A45 8mm Analog Camcorder Logo
89 people viewed this question
Top Sharp Video Cameras Experts
noel
noel
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
