Question about Kitchen Ranges
I have a summit safe and i can not open it it keeps saying ecode
Installing the 471106
I would say if you are going to make it functional by cutting a hole in your hood you leave them off if it is for show only they are block off plates so it does not get full of debris and keeps the wind out.
Apr 14, 2014 | Summit Racing Sum-471106:Racing Hood...
I forgot my password to my youniverse electronic vault, how do I open it
That is a picture of the Youniverse Electronic Lock N Safe.
Power up the safe (3 x AA battery);
Remove the batteries, then press any key on the keypad;
Replace the batteries & the safe makes a creaking sound;
Factory default open code of 0000 has now been set;
Enter 0000 on the keypad then turn knob counter-clockwise & pull door open.
Jan 05, 2014 | Summit Appliances Division Youniverse...
I have a Sentry A3810. After putting the ecode in and the "Proceed"light comes on,
We believe there is no solution to your problem as lack of opening lock on a periodic basis leads to moisture build up rusting the lock shut. If your model is still under warranty it ca be replaced. Call A1 Locksmith for additional info on drilling it open.
Jan 28, 2013 | Sentry Fireproof Safe
How do we see the ecode number on the safe?
Once you get the error light that means you are entering a user code that was deleted when the batteries went dead . Simply replace the batteries then use the master code in your owners manual to open the safe. Reprogram new user code instructions bottom of this page.
Jan 22, 2013 | Sentry Fireproof Safe
Is 93 Eagle Summit flex fuel?
I wouldn't think so. Flex fuel was developed after the car was built.
You could check with Chrysler or Mitsubishi to make sure.
Aug 25, 2012 | 1993 Eagle Summit
My son has a discovery kids safe....we lost passcode. Can it be reset? Numbers/letters on bottom of safe are: YLBSD-NI 2006 07 12330
The Discovery Kids Safe works slightly differently. When you press the reset button on the bottom of the safe, the code defaults to "1234". To set a new code, Press *, then your four-digit code, then * again.
Emergency Open: In case of malfunction, hold down "WIRE" button and push on the drawer.
Feb 15, 2011 | Discovery Kids Toys
I need the instructions for a kid's toy safe. It says YOUniverse on the front, and listing at Target says it's called a "Laser Beam Safe." Basically, my child forgot his code, and I just wanna reset...
here you go!! i just found it -- scroll down to the picture of the safehttp://summit.38pages.com/customer-service/instruction-sheets/
Sep 09, 2010 | Toys
My Summit FF560L refrigerator is not cooling- it is only one year old
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | Summit Commercial Refrigerators
I keep getting e,mails regarding the item i bought. i have never bought a item yet thru e,bay. it makes me wonder how safe the site is. some of the e,mails are asking me to summit update account imfor
check one of those mails carefully,somewhere u'l find a link to unsubscibe,press it ant one more window opens,do as directed there and u get an acknowledgement and thats it you are done.
Oct 16, 2008 | eBay Auctions
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
