Question about Bosch Axxis WFL 2060 Front Load Washer
How do i deactivate the child lock on the bosch axxis washer
  • 4,323 Answers
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Posted on Aug 28, 2010
How do i start my w/m when always show a small key on the screen?
Child lock activated, press and hold start button to de-activate it
Sep 20, 2014 | Bosch WAE20060UC Axxis Series 24" Front...
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
I am trying to start my washer and the symbol of a head with a collar appears on the dial and i am unable to change any of the controlls or start the washer.
Hi.
Samsung machines error codes are numbers and letters, then I the machine is not in fault mode, but child lock has likely kicked in.
Here is child lock icon:
Try the following:
ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal
buttons at the same time for 3 seconds.
How It Works:
1. "Child Lock" can be activated while your Washer is running.
2. Once you activate "Child Lock", all controls (except for the Power button) will be locked
until you deactivate "Child Lock".
3. The Child Lock button will be lit while it is in effect.
Here the user manual.
Jan 11, 2011 | Samsung WF218AN Front Load Washer
Washing machine shows key on the display and won't start
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Lock Symbol staying on
Hello, welcome to FixYa.
On most bosch of your class this is how you work it on & off.
Thank you for visiting "fixya" for your washer solution inquiry.
macmarkus :)
Sep 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do I switch off the child safety lock
i have the 700 series.. i push the MENU button and then when you see the option of Child Safety Lock... hit select to choose what you want
Jul 15, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do i get the child lock off to operate the machine please
You have probably inadvertently activated the child lock. You can start a cycle still, but you will need to hold the start button for approx 5 secs. Check you user guide for deactivation instruction.
use link to get manual if needed
http://www.bosch-home.co.uk/quick-links/customer-service/download-product-manuals.html
Jul 08, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Child lock flashing
Hello Lynn, Welcome to fixya. The key symbol indicates the washer has somehow been placed in the "child lock" mode, hence it won't allow any program to over-ride it. Here's what to do to deactivate it... 1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display ) 2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display. 3) Finally by pressing the start/pause button the key symbol should disappear confirming you have successfully exited the child lock program. That is the procedure for the child lock function on your Bosch washer and should solve your problem. Let me know if this was helpful to you or not, if so please take a second and rate it accordingly. Thank you for visiting "fixya" for your washer solution inquiry. good luck going forward. macmarkus :)
Jun 04, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Jan 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
619 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
