Question about Vehicle Parts & Accessories
The kill switch has activated on my car alarm after having to charge the battery and I can't get it to reset and I don't have the manual as it didn't come with the car. The car dealer can't help until Monday and I'm stuck. Any suggestions on how to find out how to fix this?
  • 22 Answers
SOURCE: mazda rx8 alarm
Search through the area in the footwell of the drivers side. There will be a very small button. This is a valet/progaming button that is on all aftermarkets. It may be by itself, it may be connected to the brain unit, or it could even be attached to the alarm antenna, which is usually on the windshield. You need to press this button when turning on the car some alarms you need to hold the button down others you just need to press it. This will shut off the alarm until it is reactivated with the key fob.
Posted on Dec 04, 2008
jpk528
  • 95 Answers
SOURCE: Car alarm won't reset after disconnecting car battery
you should try to hit the unlock button on the remotes and that should disarm it. Try disarming that, that way and if that doesnt work we will go from there
Posted on Feb 22, 2009
reynosaelect
  • 165 Answers
SOURCE: Kill switch is on and I cant deactivate
you to disconect the main harness from the alarm.and take your car to a alarm repair shop.
Posted on Mar 17, 2009
bunnydawg
  • 5158 Answers
SOURCE: battery went flat alarm does not work ,how do i reset
unplug the battery for about 15 minutes and hook it back up again... that should reset the alarm. if there is an anti-theft code for your stereo ... make sure you know it and how to enter it.
Posted on Mar 28, 2009
  • 31 Answers
SOURCE: Car alarm remote
pls change the battery for your remote and you can check it
Posted on Jul 19, 2009
1997 crown Victoria. viper alarm kill switch has turned all power to car. How do I reset
there is no override. Otherwise it would defeat the point of an immobilizer. I would find out why the alarm went off and deal with the rot cause rather than trying to bypass something made to be un-bypassable.
You may be able to reset the alarm by unplugging the battery from the car for a minute or 2 but I would start with the alarm manual to be safe. Possibly even remote the alarm and put the wiring back to stock.
Oct 16, 2016 | 1997 Ford Crown Victoria
Changed the battery and it set off the alarm. it seams like it activated a kill switch of some kind. is there a way to reset it?
You probably had your alarm set when you took out the old one. Just unlock your doors with your key fob, then disconnect the battery again for a few minutes and let it reset with the alarm off.
Mar 14, 2016 | 2000 Ford Econoline
I have an aftermarket alarm system that has drained my battery
Dear Mary. All car alarm systems drain the battery after one week of the car not being used. Also, car batteries are not always fully charged on short trips because to start the engine on each short trip it drains a tremendous amount of power and a short trips do not recharge it fully. Have the car battery checked because the alarm is always on and on standby once installed, they usually have a small back-up battery in the alarm in case of car wires to the alarm have been cut, but that battery is always kept charged by the car battery, so, that is only causing a fraction of car battery discharge. However, to stop it from draining the battery you have to disconnect the alarm, and that is not a good idea. No car alarm that I have known have caused any car battery discharge, but of course if the car is not being used, or it is driven for short periods you are likely to experience a drained battery. Some batteries last more than 5 years not stop while cheaper ones have a lesser life expectancy, but again that depends on a lot of factors, heat from the engine, not enough charge because the alternator has a burnt diode, interior lights left on, too much cranking of the engine to start it and not enough miles done to recharge the battery. Try to get the battery checked and if you do not do any driving for a week, there are a number of solar powered battery charging panels that trickle charge it on sunny days but in winter I suggest you buy a charger that you can connect to the battery to keep it charged. Once charged the charger automatically cuts off and stays on stand-by until the car alarm has discharged it a bit, then the charger sensed the voltage drop and recharges it again, repeating the cycles until you need the car to go out. These small car battery maintenance chargers are inconvenient if you're not using the car too often. Some car alarm with go off when the car battery is disconnected. It's part of the protection the alarm offer. They may not be disconnected from the car battery unless you have a key that shuts off the alarm. But remember, the key shuts off the alarm but it doesn't mean it has disconnected the power from the battery. Check the pilot light status. If it flashes after the alarm key has been turned to off, it means the power is always there. Other alarms remain silent when the car battery has been disconnected from the clamps. If you garage the car at night, you can have a switch installed in the car that switches on the power to the car alarm or you can have the switch connected to a special relay activated Kill Switch that disconnects the battery altogether, but if your car alarm starts to squeal, then you don't need this switch. so try it first, disconnect the car battery and see if the alarm goes off. If not, then the Kill Switch is an option. If it goes off, then there is nothing you can do but to try and have the car battery checked and if you're not driving much or drive short trips, either a solar charger or a Mains powered auto charger can be used to keep the battery trickle charged. But before I go, you say you got an after market car alarm. Looks like it has been wrongly wired, who know. Have it checked by whoever installed it. Good luck.
Mar 17, 2015 | Jeep 1999 Grand Cherokee Laredo
I recently purchased a car that has this alarm on it but for some reason its not working to the car but the remote itself is working. I was wondering if there is a kill switch or an activation switch that...
entertain the possibility that a previous owner got tired of the alarm going off and disabled it.
if there is a question on this board almost as common as i lost my owner's manual, it is how do i shut off this annoying alarm which goes off constantly killing my battery and annoying the whole neighborhood.
Nov 11, 2010 | Chrysler 300 Cars & Trucks
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
2000 hyundai elantra alarm goes off where is the
There is NO kill switch on the 2000 Elantra... HOWEVER, there is a thing called the Key Fob (keyless remote entry system). There is, however, a system in place called the 'starter kill' circuit and it is activated when the burglar alarm goes off.... it's called the burglar alarm relay and it is activated to prevent the engine starter system from being used. There are three ways to get the engine started in such a circumstance... 1. use the key fob to 'disarm' the system... 2. put the key in the ignition and turn it to the 'RUN" position and wait until the alarm stops (horn stops beeping and the parking lights stop flashing), then the engine will start.... 3. pull the starter relay from the UnderHood junction box and bypass the starter circuit (key in ignition and in the 'RUN' position), jumper the starter solenoid circuit to energize the solenoid to start cranking the engine -- it should start then.
Oct 03, 2009 | 2000 Hyundai Elantra
Alarm activated when it wasn't engaged. Now car won't start runn
some alarms have kill switches, but most of them prevent the car from even starting. i would consider strongly getting the remote for the alarm or Completely disconnect the alarm module.
Aug 06, 2009 | 1994 Jeep Grand Cherokee
2003 Saturn Vue Alarm - Ignition Kill
Removing the battery cable is something the alarm companies no the theifs can do. Find the valet button, this along with a few steps that you can find with your alarm manual will reset the system.
May 16, 2009 | 2003 Saturn VUE
Honda Civic Dead Battery then won't start- Kill switch?
You must fully charge the battery again , injection models are a pain
Jan 12, 2009 | 2004 Honda Civic
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
