Question about Dell UltraSharp 1504FP Monitor
Dell 1504FP - Power Button Blinking Yellow
I have two Dell 1504FP Monitors. They both have the same symptom a blinking yellow power button. The light comes on whether or not it is plugged into a computer. It also comes on immediately after plugging in power - hitting the button results in no change.
Thanks for any insight in advanced.
  • 1 more comment
  • Anonymous Aug 16, 2008
    the power button blinks yellow and i wanna know how to fix it
  • doombotex Oct 06, 2008
    Power button blinking yellow
  • Bob  Adam
    Bob Adam Mar 07, 2009
    I have yet to find a solution to this but I can tell you it is a very common problem. I have 4 or 5 of these monitors with the same problem. It is either in the power board or the inverter board, and I can't find any bad caps, or bad transistors like on other monitors.
5 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: my monitor turns yellow
Computer monitors get separate red, green and blue video signals from the computer, and if you lose the blue the result is a yellow picture. This can be caused by video card failure in the computer (very unlikely), a bad cable (fairly common), or trouble in the monitor (which is most likely what you have).
The usual problem with monitors is bad solder connections to the red, green and blue output devices. These are usually three separate transistors, but sometimes an integrated circuit that puts all three in one package is used. These outputs get pretty hot, and the heat can cause the connections on the circuit board to crack. Resoldering them usually fixes the trouble. (Sometimes the part actually fails, but bad connections are more common.)
The parts are normally in one of two places. Most commonly they are on the small circuit board you'll find right at the neck of the picture tube. Some monitors have them on the main circuit board. They may be mounted to metal heat sinks to help keep them cool. If you can identify them and resolder the connections, you'll probably get your normal picture back.
Posted on Nov 19, 2008
SOURCE: Dell Blinking Power Light
Just wanted to say Thank You for the info on this site. I had the same problem as previously posted. When powered up, the monitor showed a fast flash of the desktop and then went black, with the power indicator flashing green. I read the posts, purchased the capacitors and the 4 - 2sc5707 transistors through ebay. I ordered them on the 6th and rec'd them today. I only had one bad capacitor and one transistor that checked bad, but I ordered 5 caps and 4 transistors. When ordering the caps be careful of the height of the caps. I found this to be a problem because I ordered the 50v, 105 degree Panasonic caps that didn't fit with the enclosure attached, so I used the 4 good caps removed previously and replaced the bad one with a 470uf, 50v. 85 degree cap from Rubycon I found among my spare parts. Installed the parts and the monitor is working properly (for the last two hours) so I'm happy for as long as the repair lasts. Thanks again for the info.
Posted on Jan 09, 2009
PaulRepair
  • 66 Answers
Hi There,
I have worked on several of the Dell 17" and that is almost always the Capacitor problem.
The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
If you can get inside the frame of the monitor, and disassemble, you can find the caps by seeing a bulge on top, or even a rusty looking material on the top. Be VERY careful around the high voltage section if you do go inside.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 04, 2009
  • 49 Answers
SOURCE: I have a dell monitor (2002) and all of a sudden
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Posted on Jun 16, 2010
colbary77
  • 102 Answers
SOURCE: Display shut off and yellow light came on the
More than likely there is a capacitor inside that back that has swelled and spilled its juice out.
A blinking orange light and than no power means that it is a voltage problem. These are not hard to open up and find the problem. You would be surprised at how little stuff is actually inside one of these.
Posted on Jul 02, 2011
Yellow blinking light on power button
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 15, 2014 | Dell Studio XPS Desktop Computer
Yellow light power button
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 10, 2013 | Dell OPTIPLEX 745 PC Desktop
I have a Dell Dimension E521. When I cut the power on everything comes on including the monitor, but the monitor will stay black. It does say something about power save hit any button but the screen
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Sep 10, 2012 | Dell Dimension E521 PC Desktop
When i turn power on my dell gx520 just blinks yellow and nothing else, nothing else at all
If the power button light is blinking yellow . Generally it means the problem is with the power supply and needs to be replaced . If after replacing the power supply the problem is not solved it would be the motherboard failure.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
To know more on how to troubleshoot the system visit the following link
Dell support site link
Thank you for using Fixya
Proton
Oct 08, 2010 | Dell OptiPlex GX520 PC Desktop
Power button is blinking yellow and won't power up
First, you may want to hold down the power button 20-30 seconds and see if you have results. It may be in "standby." Otherwise, a blinking yellow is typically a sign of a bad power supply. You would need to obtain a new power supply. Please leave feedback if this is helpful.
Sep 21, 2010 | Dell Dimension 4300 PC Desktop
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
May 04, 2010 | Dell XPS 410 PC Desktop
Dell? OptiPlex? SX280 blinking yellow what is that
blinking yellow light on the power button of a Dell system is a possible power supply issue. press the eject button on the dvd drive while the power button flashes yellow light. if the disc trays wont come out, you need to replace the power supply. hope it helps. good day.
Jan 07, 2010 | Dell OptiPlex SX280 PC Desktop
Dell dimension e310 desk top will not power on
If the POWER Button on the TOWER is blinking AMBER (Yellow) then the most likely failure point is the POWER SUPPLY in the Tower.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226001
Dec 21, 2009 | Dell Dimension E310 PC Desktop
Have a yellow amber light blinking
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
Blinking power light
check your power supply. A flashing amber power button usually means its gone bad
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
279 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
