Question about Cell Phones
How do I remove the sim card in a GZ One Rock phone?
  • 1 more comment
  • jmaqha Aug 28, 2010
    I was told that the sim card is pre installed and it can be accessed by removing the plate under the battery. I just want to make sure before doing so.
    how do u remove it... do u have a pic of what it is?? will it ruin the phone by removing it or can it be put back in??? I am desperate....
  • jmaqha Sep 05, 2010
    if the sim is removed can text and other deleted data be retrieved???
    President:
  • Cell Phones Master
  • 1,932 Answers
Please contact your wireless provider to find out if your device contains a SIM card and for assistance on how to remove it.Only they can remove it
Thank You
Posted on Sep 06, 2010
    President:
  • 2,559 Answers
If in fact it does have the sim, it is located under the metal plate below the battery.
Posted on Aug 28, 2010
  • 1 more comment
  • Randy Hough
    Randy Hough Aug 29, 2010
    It will not ruin the phone but since it's a hard sim and not meant to be removed, pics are not available
  • jmaqha Aug 30, 2010
    when the old phone was broke I believe they switched sim cards at the verizon store,.,,,, they took it in the back..... do u think that would have been done...... if I open and remove it... can I put it back??? Need some deleted text to prove some work issues..... Thank You
  • jmaqha Aug 31, 2010
    where can i get the tool to take the back of the phone off to take out the plate???
  • 4,737 Answers
Casio G'zOne Rock has no sim card slot, means it's a CDMA (Code Division Multiple Access) phone with which the network is operated by the Network Operator. In other word, it has only one selected network band. You can't install/insert sim card.
For more details, you can visit here and check out... click here
If you need further help, don't hesitate to let me know.
Good luck.
Thanks for using FixYa.
  • Lebanon Raingam
    Lebanon Raingam Aug 28, 2010
    Well, I am sorry, if your handset is another Casio G'zOne Rock model, but what I know of Casio G'zOne Rock has no sim card and is CDMA Phone. There's a memory card but there's no sim card.
    Good luck.
    I am at such a loss..... when we switched phones they said they took something from one phone to the next.....and it ahd the phone memory in it... we did not have a seperated memory card installed / purchased..... I am kinda desperate.....
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Invalid sim card
what has case have to do with sim card? If you switched phones, the smart phones require an upgraded sim card to operate.
Apr 10, 2014 | Samsung Purple Stripe Cover Case For ROCK...
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Gz one boulder will not turn back on..it quit on me one day and iv chaged it and it stl ownt turn on
I am re-posting the following answer from a similar question..
Connect to the charger just long enough for the screen to power on, then immediately disconnect the charger before it goes into charging mode. . -- It should power up and be ready for use.in a couple seconds.
I have found that only when the battery gets completely drained, that the Gzone Rock often will not power back up on it's own, even though the battery has been successfully recharged.
By connecting the to the charger it will initiate the boot-up of the phone - but you must remove it before it displays the charging screen again, otherwise it still won't come on and boot.
Sep 10, 2011 | Casio G'zOne Rock Cell Phone
How do i clean my sim card
  • Hi
    To clean your sim card, remove the SIM card from the phone. Rub a dense white eraser along the exposed metal part of the SIM card. Make sure that the eraser is brand new, otherwise you could get the SIM card even dirtier.
  • Remove the back of your phone and the SIM card. Spray canned air into the back of the phone, removing all dust and dirt particles, especially those that could be stuck in the SIM card groove.
    Regards
  • Jun 30, 2011 | Nokia 2220 Cell Phone
    Internal screen is broken. Where can I send it to get it repaired?
    the out side cover Gz one rock 731 , circle vew has a scrach .I would like to replace it. there is only (2) screws to take a part , the outer cover is holding it together .
    THIS THE OUTER PLASTIC TOP FLIP OPEN TO . WERE THE TIME IS VEWED
    PLEASE ADVISE
    N9GDY@YAHOO.COM Harry Hartmann Wisconsin,54905
    Jan 11, 2011 | Casio G'zOne Rock Cell Phone
    How do I remove the Sim card from a Motorola Razr V3M cell phone?
    it is very easy to remove.just use your finger to open the back cover of the phone, remove the battery close to where the battery terminal is, and slide out the Sim card out.
    But if you can not remove the Sim card with you finger, just get s screw on something you can use to pull the back cover and the battery out, then you can get access to your Sim card.
    Good luck to you.
    Mar 15, 2010 | Motorola Mobility RAZR V3m Cellular Phone
    ASUS P527 Mobile stuck on Blue StartUp Screen
    Firmware is corrupt you need to hard reset it,
    Press Reset hole with stylus tip and power on the phone and then follow the instructions on screen.
    Jun 06, 2009 | ASUS P527 Smartphone
    Phone not reading sim card
    dont worry there is some prblm in ur sim pls contact ur customer care there is no prblm in ur phone
    Oct 11, 2008 | Motorola Mobility SLVR L7 Cellular Phone
    Cell Phones Logo
    578 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
