Question about Dryers
Hi guys got a simpson maxidry 1000p dryer problem is that it has no heat is it stuffed or can it be fixed
  • 3,230 Answers
Well first of all you may check out the Heating element - If a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter (volt meter). No continuity means the element is bad and you need to replace it (electric heating element not repairable) further you may check the Thermal fuse - A thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse, which is about an inch long, usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. And the last dought goes on the Wiring - you need to deep inspect the wiring in your dryer and check for any burnt sign.
Good Luck!!
Thanks for using FixYa!!
Posted on Aug 28, 2010
Testimonial: "thanks for your time very helpfull "
Can you please tell me where I can get a Simpson Maxidry 1000 user manual or any other kind of manual for this dryer?
Try this link:
http://fasterbetterdownloads.com/simpson-maxidry-1000p-user-manual/
Jun 20, 2015 | Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
No power to motor checked continuity of main switch the door microswitch is brand new and has continuity so to has the spring loaded idler circuit breaker switch, dryer was running after pulled down and...
I know you have already checked but first things first: breaker is not tripped, have 220 volts at outlet, have 220 volts at terminal lugs of dryer, if yes to all then some motors have a switch on the motor, do not know if yours will, it is where the power plugs into the motor, one is a trip the other a reset. Now we get into the other aspects of why dryers will not start, since the door switch is eliminated, then it is on to the others, here is a website that will help, now if all checks good feel free to post, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 28, 2010 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Apr 11, 2010 | Dryers
Simpson Maxidry 457 not heating
Check thermal cut outs/ Element Should read around 32 ohms on a multimeter if its ok...
Apr 09, 2010 | Dryers
Clothes Dryer tripping house circuit breaker
If it is breaking the main circuit of the house there is something wrong. It should throw the breaker to the dryer only. It sounds like you are having a problem with a short between the main breaker and sub panel in the house. Is there any way you can move the breaker in the panel to a different place on the same panel to see if it is that circuit only. If not check the outlet and the plug on the dryer and make sure the wiring is connected correctly.
Aug 03, 2009 | Dryers
How to fix a Simpson Maxidry 1000p?
Idler pulley and spring have come off while cleaning dust from inside cabinet a diagram whould be a great help as Im 500kms from nearest service place simpson maxidry 1000p Ray bushed
Jul 26, 2008 | Dryers
Dryers Logo
337 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
