Question about RCA 27V530T 27" TV
My 27"rca tv is stuck in standby mode the will not come on how do i fix this problem without a remote
SOURCE: Video Mode - Orion 27" TV - Model stv2555A
It is the TV/AV button on your remote. And for most, it's a buttong labeled 'input' -RAJ
Posted on Sep 28, 2007
  • 556 Answers
SOURCE: RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Posted on Oct 06, 2007
praky16
  • 744 Answers
SOURCE: Dmtech TV is stuck in stanby mode
The problem IS PROBABLY BEING CAUSED BY A SHORTED POWER REGULATOR (MX084 ) OR AN OPEN FUSEABLE RESISTOR IN THE POPWER SUPPLY...
thank u rate me!!
Posted on Feb 12, 2009
SOURCE: How do i get my symphonic tv into video mode without remote?
Hi Guys
This will help you a looooot
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 16, 2009
ginko
  • 19396 Answers
SOURCE: tv has got stuck on standby mode
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
How to unlock without remote
RCA TruFlat 27F520T 27" TV Unlock without remote ... - Fixya
www.fixya.com > ... > RCA > RCA TruFlat 27F520T 27" TV
Question about Apex Digital Standard (CRT) Televisions. 1 Answer ... unlock key lg lcd tv without remote how do I unlock an lg tv without using the remote?
unlock child lock tv without remote Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your unlock child lock tv without remote question. Get free help, tips ... How to off child lock off in my panasonic tv without a remote? ... tv without aremote? iv ... Are you a Standard (CRT) Televisions Expert? Answer questions ...
How to Unlock a TV Without a Remote ' eHow
www.ehow.com > Tech
How to Unlock a TV Without a Remote. In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote.
How to unlock without remote control model - Standard (CRT)
Jan 20, 2016 | Televison & Video
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
RCA truflat tv locked and is on standby mode. I have a universal remote but the remote will not work if the tv is on standby I need to find out how to unlock the tv with out the remote so I could turn it...
Okay, do this.
On the top of the t.v. itself, hold down the Volume+ (up) and the Menu button down at the same time. This will turn off the "power lock." This is also how you turn on the "power lock." (Though I can't think of a reason anyone would ever want to do this.)
Also the problem ca be from factory defect in the if and video section of the tv only the manufacturer could remedy that.take it to a tech so that the video board and the IF board be replaced
Hope it helps...Thanks ....feel free to contact me back ....Ok ?..
Apr 23, 2011 | RCA TruFlat 27F520T 27" TV
Girlfriend lost remote for RCA F27645. I know I
If I'm Correct There Is Only One Set Of Inputs On That Model TV. What Inputs R U Reffering To?
Jul 12, 2010 | RCA F27645 27" TV
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
Dec 18, 2009 | Sanyo DS27510 27" TV
RCA console TV need to change to video mode without remote
Your cable box has a program mode in
it .You may be able to program it to change
inputs on your tv Is it a comcast remote?
Jun 30, 2009 | RCA G27649 27" TV
Rec tru flat is stuck in standby mode
chechk the horizontal output of your tv if deffective or not.
Jan 11, 2009 | RCA TruFlat 27F520T 27" TV
Oct 02, 2007 | RCA 27F530T 27" TV
RCA 27V530T 27" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
