Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The soap compartment will not open during the wash cycle.
  • 4,323 Answers
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn’t allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn’t receive 120 volts, then it’ll not work. Please check the voltage to the wax motor/Bi-metal strip, also inspect the connections to these.
Please revert for any further assistance.
Daniel
Posted on Aug 28, 2010
catriver
  • 878 Answers
SOURCE: soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Posted on Jan 16, 2008
  • 1003 Answers
SOURCE: soap door won't open during wash cycle
IT SEEMS YOU SOAP DOOR HAS A BAD SOLENOID ACUATOR OR RELAY
Posted on Jan 18, 2008
  • 351 Answers
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
Karthik316
  • 187 Answers
SOURCE: soap dispenser does not open during wash cycle
  • Hi,
    please try this...
    imer:
            On mechanical set ups the timer is attached to the detergent cup by an actuator arm. This arm is usually plastic, and if it is broken or otherwise defective then the detergent cup wont be opened. Check the linkage to make sure it is functioning correctly.
    Bi-metal switch or wax motor:
            The bi-metal switch is simply a very precise device that warps, bends, or otherwise deforms when power is supplied to it. The timer operates the bi-metal switch, which inside the dishwasher door. Then the switch is supplied with power and it is working properly, the bi-metal switch deforms away from the latch holding the detergent cup closed and the cup opens dumping the detergent into the washer.
            Some dishwashers have this switch wired through the motor power feed or the heating element. If they are defective then the detergent door will not operate correctly. If the switch itself is defective then you will need to replace it. Another type of mechanism is a wax motor. Wax motors are sealed units filled with wax and found in newer dishwashers and work by heating the wax and forcing up a piston which in turn mechanically opens the detergent cup door. This type of device is also controlled by the timer.
    Detergent cup:
            Sometimes the detergent cup becomes built up with old detergent that prevents it from opening correctly. It's usually a simple fix to clean this out. If cleaning it is impossible then you may need to replace the cup assembly.
    please rate my suggestion..
Posted on Apr 14, 2009
My wirlpool dishwasher tab compartment don't open through the wash cycle
Clean it out with boiling water, soap residue is making it stick. The compartment is opened by heat during the wash cycle.
Dec 23, 2011 | Dishwashers
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
My detergent compartment won't open during the wash cycle, how can I fix it?
heatman101
Nov 04, 2010 | Whirlpool Dishwashers
The dishwasher completed it cycle but didn't use any dish soap and didn't clean the dishes.
It appears that, the soap compartment box did not open during the wash cycle. First check that whether this is the problem. If water flow is good and you are convinced that, the wash has taken place without the soap then, check the soap box relay latch ( if you can do it yourself.)
If this is not possible you have take the help of the service provider authorized by the co.
You can keep soap in a small cup and place it in the upper tray in a suitable place and run the wash till the repairs are attended!.
Oct 05, 2010 | Maytag Dishwashers
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
The main wash door doesnt open
switch to pre-measured tablets,and throw the tablet directly into the tank(d/w..)it works better that way anyways...most dispensers are very expensive also
Mar 03, 2010 | Dishwashers
Secondary soap dish won't open
i think you mean jet dry compartment.change dispenser. in some cases there is a kit but its better to replace new dispenser
Mar 02, 2010 | Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Dishwasher soap cup lid will not open during a wash cycle
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Soap door won't open during wash cycle
Mar 01, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
148 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
