HI. If there is any breakdown in communication between the machine controller and the motor controller, “CE” flashes and the unit beeps once.
Some common causes of “CE” errors will include:
1. Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins and reconnecting them to their respective locations.
2. Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3. Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a “CE” error will occur.
4. Drive motor thermal protector has opened.
5. Motor controller is not powered or fuse has opened. Replace motor controller.
You can Press STOP/CANCEL to clear the display.
Click Here to view the service manual for this unit. This manual will have all the component accessing procedures and resistance charts needed to repair the unit. please allow up to 5 minutes for the complete file to download to your browser and save it immediately for future usage once it has finished downloading properly.
