Question about Dishwashers
LG dishwasher Model LDS5811BB Stops while running, displays code OE. What does this mean?
  • 8,197 Answers
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
Or else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on Aug 28, 2010
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
LG model # LDS5811st stops and displays OE. What does that stand for
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 22, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
I have an LG Diswasher LDS5811BB Bought in 2006
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 29, 2009 | LG Dishwashers
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
I have an LG dishwasher that is stops and flashes OE on the display
Check your instruction book to see what the fault code OE lists as the fault
Oct 09, 2008 | Dishwashers
Era codes
The PF code means that there is a power problem with your unit. Make sure that you're not having issues with your outlet.  Check the connection at the junction box to make sure they're good and tight.  If both of those check out ok, open the front panel of the dishwasher and check the wiring harness there.  About 1/3 of the way up from the bottom of the door, inspect the wire harness for any signs of cracks or breaks in the wire.  Repair the damaged wires and that should take care of your PF issues.
Jun 24, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
152 people viewed this question
Top Dishwashers Experts
Owen Barnes
