Question about Philips 43PP9202 43" Rear Projection Television
My phillips model 60pp920217f has a horrible picture...no green to the color
My 60 inc rear projection tv has lost its picture quality. THe picture is mostly bright reds and blues and no greens.. I have green halo's over words at the bottom of my screen and the blues and reds still dont look bright and vivid...any ideas on what that may be..btw i have worked on the convergence and multipoints but no luck with that....
  • tvproblemguy May 07, 2008
    Can that be done at home or buy a professional. If done by a professional what is the price range on having this done..Just a estimate if you could...also when there are words on the screen just above them will be the reflection of the word in green..and after changing the cool with the picture be clear and not cloudy and colorless.
  • tvproblemguy May 08, 2008
    ok now the color seems fine but a the bottom of the screen if there are words (more noticeable) they seem to be written right above it in green..like a double image..this is only at the bottom. I restored factory covergence and it still appears . When I ran the service convergence and did a test it says that 1,2,3,4 not lined up. Any ideas?
  • Philips Master
  • 8,617 Answers
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
Posted on May 07, 2008
  • Sonny Berry
    Sonny Berry May 07, 2008
    The coolant change can be done. However if you dont feel comfortable with removing and reinstalling the picture tube, you may want to get a shop to do it, they all charge different prices, you may want to call and ask what they charge to change the coolant in the CRTs.
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection 60 color lamps off focus
You can't adjust this. Your convergence amplifiers are bad and must be replaced. $250-$350 by repair shop.
Jul 08, 2009 | Televison & Video
Double images-picture on tv is in unalligned red and green colors
You need the Phillips DPTV305 - DPTV345 Chassis convergence repair kit which is available at the following link. the kits contain the parts and detailed instructions on how to do the repair.Just click on the phillips repair kits page.
http://tvrepairkits.net/
Jun 23, 2009 | Philips 60PP9202 60" Rear Projection...
Screen color/picture quality
You can access the menu by hitting two buttons on the TV itself at the same time. You then adjust by hitting the up/down buttons.
The double pictures u mention sounds like a convergence problem.
If adjusting the convergence via the menu does not work
you would need to order 2 parts and be able to solder. A rather inexpensive repair if you can do it yourself.
For step by step info on how to repair click below
Good Luck,
Paula
http://techghetto.com/tv-repair/
Jan 14, 2009 | Philips 60PP9202 60" Rear Projection...
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Phillips 60" rear projection 60pp920217f
There are two major possible cause. The picture tube or the power unit. I had the same problem. Fortunately it turned out to be the lesser of both evils. The power unit. The repair shop was able to rebuild a power unit for less than the price as purchasing a 32' LCD TV. Less than $400.00
Apr 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 43PP9202 43" Rear Projection Television Logo
232 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
