Whirlpool ice maker not making ice - Washing Machines
  • 172 Answers
Hi txjulieb,
I would recommend you turn the icemaker off at wait about an hour. Go back to the refrigerator and turn the icemaker back on you should see the arm start to rise. If the timer never starts and your freezer is getting to 0 degrees then you have a bad icemaker, If the icemaker starts running about 1 minute into its cycle you will should hear a buzzing sound as the icemaker calls for water. If you hear this and no water comes in then you have a bad water inlet valve. One other possible would be your water line going into the back of the freezer is frozen, if that is the case thaw the line and replace the valve. I hope this helps and good luck to you. Mike
Posted on May 07, 2008
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Whirlpool Gold Model # GD5SHGXLB01. The ice maker does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 06, 2010 | Whirlpool Refrigerators
Whirlpool side by side ED5FTGXKQ02 ice maker very slow making ice,replaced filter,I'm not using that much ice,
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Feb 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Washing Machines Logo
193 people viewed this question
Top Washing Machines Experts
