Question about HP Pavilion dv7-1130us laptop
The external display stays muted and plays no sound but when I use the headphone port the sounds work. I cant get the laptop speakers to produce any sound though.
    Scholar:
  • 156 Answers
Go to control panel and go to sound and hardware (Just go to anything that says sound)!
Then go to sound and audio devices!
Go to Audio and change the default until sound comes out of tv!
Posted on Aug 29, 2010
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Headphones for a laptop not working
click on Sound
select that!!
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
No sound
  1. Did you have the correct audio-drivers installed on the system?
  2. Maybe the speakers are muted in the audio settings?
  3. You could try to attach some external speakers, such as an amplifier or a headphone to the laptop.
Greetings...
Mar 21, 2012 | Dell Dimension 8300 PC Desktop
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
How do i get the sound the sound to work?
That one could be a couple things. Either you have a lose connection to the external speakers or you have the sound output on mute in the sound menu. Check your menu options the sound card is ok or you wouldnt have sound in any output slot.
Dec 29, 2009 | MSI M510C Notebook
My Dell Inspiron 6000 stopped playing sound. I uninstalled and reinstalled SigmaTel driver. This did not work.
Does it show that the device is working properly in the device manager? You could try and use system restore to roll back windows to a time when the sound was working. Windows may have updated software and caused problem with audio. If you roll back the system to a time when you know the sound was working then the on board audio may be defective. Have you tried plugging in headphones in the headphone jack and check if there is sound? Are the sound properties muted? The laptop speakers or internal amp may have stopped working also.
Sep 10, 2009 | Dell Computers & Internet
HP Pavilion dv7-1130us laptop Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
