Question about Sony KP-41T65 41" Rear Projection Television
Philips 60" hdtv. Convergence problem
TV objects are red on the right and green on the left. Double image almost. Tried adjusting red convergence, will move up and down but not left to right. It is off to the right but will not move to the left.
  • Fitzy0571 May 07, 2008
    It is a Philips 60" hdtv rear projection. Model#60PP9202/17F
    I will order the IC's. Thanks alot bud.
  • Sony Master
  • 8,617 Answers
What is the model number of your set and I will be able to help you with your problem.
Posted on May 07, 2008
  • Sonny Berry
    Sonny Berry May 07, 2008
    You need to replace both convergence ICs numbers STK392-120. You can get replacements at the following link and they provide free instalation instructions with pics and also free on line tech support so you can do the repair yourself saving about 400.00 heres the link.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    youre welcome. I work for that site as a support tech. You will like that site they go the extra distance to get your set working again, and the tech supports unlimited even the instant messageing tech support is free.
The screen is showing a red outline around objects and in double vision.
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 23, 2010 | Philips 60PP9202 60" Rear Projection...
Philips projection HDTV 51PP9200D/37. Convergence problem
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 13, 2009 | Philips 51PP9200D Television
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Picture seems to be losing its sharpness and colors bleed
  • Screen looks 3D
Feb 22, 2009 | Philips 60PP9401 60" Rear Projection...
Double Image Red and Green
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Red and Green Arch
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
Jul 07, 2008 | Philips 60PP9363 60" Rear Projection...
Sony KP-41T65 41" Rear Projection Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
