Question about Kenmore 88752 Top Load Stacked Washer / Dryer
I have a Kenmore stackable Washer/Dryer (Model 110.88752792). There's something wrong with the mechanisms that tell the washer its lid is closed. For a couple months now I've had to reopen and close it multiple times throughout the wash cycle to get it to continue working, but this time it stopped working mid-cycle and I can't get it to work again.
  • Kenmore Master
  • 17,129 Answers
There is a limit switch that triggers a safey mechanism to the controller board to stop the motor/pause in event of the door lid being open, This safety is incorporated to prevent accidents when the door is opened.
So in the first place trace the switch and check for contact loss . If s replace.
However your will need to check if there is any further complaint to the controller unit and the sensors that trigger the program to move forward.
Hope there is power in the board, if not start from the begining.Powerr to unit, power to controller, input sequence to controllerr to output to motor.
Posted on Aug 28, 2010
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Stackable washer & dryer, Serial #xe34301623, Model# 417.94802301, just filled washer with soap & water and turned dial and pulled to start, no action at all. Checked for water leaks, checked...
Hi- Check the lid switch, it will not run if the lid switch is not working. It should be on the right side of where the lid closes onto the top, you can put an screwdriver down the hole and see if the switch is engaging, sometimes they break off, check to see that the switch actuator is attached to the door as well. This model has the locking type of lid switch and some part of it may be faulty. If you are handy you could test the switch for power and continuity by taking the top of the washer off (unplug the machine). If at all unsure call a Tech to come out and look at it. Hope this helps, good luck.
Sep 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
388 people viewed this question
fordexpert
Mike Squire
Robert Rankin
