Question about Cameras
Memory card says it needs to be formatted but i have pics on it and I need them..please help I will be waiting!
Ok i have a Nikon coolpix s210 digital camera. Today i took out the memory card and tried to upload the pics onto my laptop like i usually do..but it wasnt reading the card (it has done this many times, i put it in and the computer beeps to let me know something was attached but nothing pops up and when i go to my computer to open the 'removable' disc folder or whatever its called there is no option for that, it usually takes me numerous times to put in and take out the sd card before the computer actually reads it and lets me open it) so i tried it a few times and it still wasnt working..i took out the sd card and i slid the little gray swith on the card up and down and put it back in and it says the card is not formatted and it needs to be formatted..i put it into the camera and it says the same thing. PLEASE HELP i cannot lose all the pictures on my sd card...how can i possibly get them on my computer before i format the sd card? it wont even let me look at the pics or anything..i tried to upload the pics through the usb cord from my camera but it says there are no pictures or files..please please please help me i will be sitting here waiting for a response, and i will greatly appreciate it..thank you!!!!
  • 1 more comment
  • Anonymous May 24, 2008
    mine is saying the same although i have had it in the pc before with no hassles?
  • Anonymous May 26, 2008
    Mine is doing the same thing too! I have a Nikon Coolpix LX, am travelling in SE Asia with my family, and have my daughter's graduation photos on the disc. It was working just fine, until 2 days ago. I'm using an OPTEX card reader, don't have a camera cable with me. I have 2 cards with me, a 1gig and 2gig, and I'm getting the same message on both. Interestingly, I can still take pix and view them on camera. I just can't download onto my laptop. Any help would be greatly appreciated!
  • Anonymous Jul 24, 2008
I had the same problem with my 4Gb card that has 750 photos on it. I tried doing different things, however, it did not work. At last I took the card out and blew on its chips, gave it a good shake and put it back. Then, the miracle happened. It could read all my photos. I guess there was some dust that had accumulated on the chips at the back of the card. Hope it can help you, too.
Posted on Nov 06, 2009
    Sniper:
  • 55 Answers
Dont worry, you can try to recover the files from memory card which says needs to format, take a look at this guide that helped me before
Recover data from asks to formatted memory card
hope this helps.
Posted on May 16, 2013
    Problem Solver:
  • 5 Answers
My SD card was doing the same thing. I t took awhile but i figured out how to solve the formatting issue. I had used my card in two different cameras a canon 790is and a cheap kodak that my daughter had. the problem was the pics that were takin on the kodac would show up as unidentified pics when i placed the card into the canon. Luckily it was only two pics. I deleted the two pics. took the card out plugged it into my laptop and boom it worked. I was able to download the remaining 125 pics without any format error. Hope this helped out.
Posted on Jun 10, 2009
It happened to me too!! It happened to my cell phone memory card, I need help, I don't want to format it , so what should i do????
Posted on May 31, 2012
  • 3 Answers
Go eat a bag of dicks ugly
Posted on Dec 25, 2011
I have the same problem too
Posted on Aug 23, 2008
I had the same problems too! Now i just do rough sketches instead of taking pics that way i dont have to worry about it anymore. Good luck!
Posted on Jul 18, 2008
  • 98829 Answers
SOURCE: can nikon colpix S210 be used for webcam.
You can't. The S210 was designed as a camera, storing high-resolution pictures (and videos) to a memory card. It was not designed to stream low-resolution videos live to another device.
Posted on Jun 21, 2010
Rammsteins
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
  • 98829 Answers
SOURCE: How do I update my Nikon Coolpix S210 camera firmware?
There are no official firmware updates for the S210. The currently available firmware updates are posted at
http://support.nikontech.com/app/answers/detail/a_id/13783
If you do want to update it with some other piece of firmware, simply put it onto an SD card in a folder named "firmware" and plug the card into the camera.
Posted on Jun 03, 2010
  • 98829 Answers
SOURCE: drivers for a nikon coolpix s210 for a MAC
http://support.nikontech.com/app/answers/detail/a_id/61
How do i delete all the picutes at once on my cool pix s210
You can clear ALL pictures from the card by formatting it. In fact, the memory card should be formatted EVERY time you finish downloading pictures from it. This will prevent later problems.
To format the card in the L20, press MENU, select Setup (the wrench icon), then select "Format card" (the memory card icon).
Jan 13, 2011 | Nikon Coolpix S210 Digital Camera
My camera will not save photos to memory card
Please try to take out your memory carrd and format it in your PC. there after save some files/photos to the meory card to test the memory. Format it once again and reinsert into yourr camera. If this wont work ther is a fault within the camera processor controller which may require help. replace memory card if otherwise. Hope you try. Good day
Aug 13, 2010 | Nikon Coolpix S210 Digital Camera
Nikon coolpix sd cards read empty in any computer but when in the camera i can see all the pics and sd card reds almost full
This happened to me before with a Nikon Coolpix camera as well. this is due to a virus obtained by the memory card when I inserted it to a friend's computer. What I did was I typed in the direct path of the pictures folder into the address bar, say if you are using a memory card reader and says F: as the drive for your device, you can try to go directly into the pictures folder by typing in F:DCIM and press enter. Once you are able to access your pictures folder copy them all into your computer and format the memory card after using your camera and you are ready to go. Hope this one works for you.
May 10, 2010 | Nikon Coolpix S210 Digital Camera
Lost pics
If memory card has not been formatted yet then use Pandora Recovery software to retrieve deleted picture files from camera memory card.
Click Pandora Link to download software, its free.
Thanks.
Mar 03, 2010 | Nikon Coolpix S210 Digital Camera
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
When the memory card is inserted in the camera, the
Format card option appears in the setup menu.
Hope this helps
Ian
Aug 09, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Camera is not saving pic's in memory card
go into the camera settings and check the storage selection..
it may have internal memory as well as the card
Jul 30, 2009 | Nikon Coolpix S210 Digital Camera
Pictures not accessible on memory card
Nope. Ur memory card might have been formated by the camera with a different file system.
So use your camera to access your pics and to transfer to PC.
Feb 28, 2009 | Nikon Coolpix S210 Digital Camera
this memory card not formatted error is quite famous, I saw it before, but luckily I found the solution, check it out
Fix Memory card not formatted error and recover files
hope that you can find the help as me.
Jan 30, 2009 | Nikon Coolpix S210 Digital Camera
Cameras Logo
10,221 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
