Question about Kenmore 63942 Dryer
Loud sound when spinning at high speed - Kenmore 63942 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers need lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Remove the filter also.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Aug 28, 2010
Runs fine on low speed hums on high speed (turns slowly) is it a capacitor problem, internal windings or controller?
Motor itself is the culprit.
Capacitor helps the motor to start spinning from a dead stop, so NO, it is not a capacitor problem.
Probably high speed windings. Means - New Motor needed.
Another possibility, is the controller could be sending power to "Both" sides of the windings: High speed & Low speed at the same time. But normally when this happens, you hear a loud buzz type of sound, motor will spin slowly - if at all.
Good Luck
Mar 11, 2015 | Pool & Spa
Wet clothes after final spin cycle
There are two speed (or three) on most washer motors and what happens is that a motor speed will stop functioning--it will wash the clothes, but the high speed will not function. This also could be the controller, but more likely it is centered at the motor. It the motor is functioning, it coulfd be in the transmission of the machine--which may be the problenm since you heard a loud noise. I am not familiar with your machine, there could be an electronic switch for the transmission to go into high speed as well that has gone bad. I wish I had more direct knowledge of your machine.
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Still wet clothes
It sounds like the high speed of your motor is not functioning which tells me it is either burnt and needs to be replaced, or that the control dial is malfunctioning. Because those motors have two or three speeds, usually one of the speeds of the motor is malfunctioning. Always check connections too, and see if it functions in the spin on another cycle. Best of luck. C
Mar 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag neptune MAH4000AWW Very loud noise when spinning
I found this on line ... 6/15/09 . Does your Maytag Neptune front loader sound like a runaway freight train when it is in high speed spin cycle? 2. Is your Neptune getting so loud that you cannot be in the same room while it is spinning your clothes? It sounds like your bearings may need some attention if you answered YES to the questions See www.neptunebearing.com ... Frank frankbusch@comcast.net
Sep 08, 2008 | Washing Machines
Drum Speed - Unstable
The spin bearing or basket drive may be worn. When these components are worn-they prevent the drum from spinning freely, and usually you hear a loud sound during the spin mode.
Sep 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer
Brake assembly is failing.If the noise is like a loud roar sound,than its not a good idea to fix this.The labor is going to be high.
Apr 29, 2008 | Maytag Performa PAV2200
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ecosmart loud during spin cycle
My majestic sounds exactly the same on the spin cycle and I wondered what the problem was. Is your unit still under warranty? If so, call the customer service line and get a repair started. I am a firm believer in warranty work on products I have purchased. WE pay hard earned cold cash on our consumer products and WE should be taken care of properly.
Good luck and please let us know what the solution was to your problem.
Jan 13, 2008 | Fisher Paykel EcoSmart GWL15
Loud winding sound
that's normal should sound like a lear jet engine cranking up load whining sound is that what your hearing mines been doing it for about 9 years high speed spin is 800 rpm let me know if that's not the sound besides the control bd not much there to go wrong
Dec 20, 2007 | Frigidaire Affinity ATF7000EG
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
