Question about Linksys WRVS4400N Wireless Router
I have a Linksys WRVS4400N Router configured to forward port 5900 to an inside server. When outside of the local network I port scan the router to see the ports closed...they are there but closed. any idea? I just want to get vnc to work through the cable modem and router to the server.
marked
  • 6487 Answers
SOURCE: port forward 5900
You can follow the steps here on how to forward port 5900 to your router, just go to this link http://portforward.com/english/routers/port_forwarding/Linksys/WRT54GSv4/RealVNC.htm
Posted on Jan 05, 2009
rcsnet
  • 15 Answers
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM junodr@yahoo.com or through this website.
once
Posted on Jan 13, 2009
  • 60 Answers
SOURCE: Port forward VNC server
What VNC product are you using? RealVNC? TightVNC? UltraVNC? The VNC software you installed will have a port# assigned to it by default (probably 5900) which can be configured. Find out what that is and forward that port# to the IP of your VNC "server." That should do it.
(don't fogot about any software firewalls on the VNC "server" machine)
Posted on Jan 19, 2010
puertobori
  • 7733 Answers
SOURCE: My VNC server show this
Use ths Dlink simulator ->lnk .
Posted on Oct 06, 2010
SOURCE: Not sure if the router
Yes it can support multiple connection but you have to configure this to the application itself. Right click on the V icon in the system tray, sekect "options" and go to the "sharing tab". You can configure your preferred settings from there.
Hope this helps.
Posted on Apr 28, 2011
IP Camera Port Forwarding
The best way to find out what is being forwarded is to look at the traffic with the Wireshark program. You can install this from the Internet.
Wireshark is perfect for this but you have to learn how to filter traffic or there will be too much information collected. It is also regarded as (a bit of) a burglar tool so don't use it at work without permission.
I would recommend that you connect a PC to a wired port on the inside LAN and configure the router to forward outside requests to the PC. When you run wireshark on the inside PC with a filter that selects for tcp port 80 (or tcp port == 80) you will see traffic forwarded from the router.
Use your outside machine to request a page from the router's outside address and the port you are forwarding. If you have forwarding set up correctly, you should see a TCP connection attempt. If you are not running a web server on the inside PC, there will be no connection so you will only see the SYN packet from.
outside. If you have a web server on port 80, you will see a fair number of packets in both directions. (SYN -- SYN-ACK -- SYN -- some HTTP Headers an HTTP GET / a response and FIN -- FIN-ACK).
Once you see successful port forwarding (your are forwarding TCP packets, right?) at the PC, change the destination of the forwarding to the camera.
This is really technical but Wireshark is so good that it is quite easy to use.
Sep 10, 2012 | Computers & Internet
Port forward VNC server. Not able to connect vnc viwer from external network.
Dec 07, 2009 | Linksys BEFSX41 Router (DHBEFSX41)
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
How to have NAT open on EDimax router BR-6216mg
The router of course allows you to forward ports to different IP’s. It does not have any pre-configured application ports to choose from though. It also supports Virtual Server so you can set up a server inside the network and direct the traffic from outside to it.Some applications require multiple connections to work.When you log into the router(it uses web interface)it gives you an option which says NAT.On this screen you can set up a trigger port for an application which will open up a range of ports for the application. Edimax has included a list of popular applications (games and applications) which can be selected. If the game or application you are using is not included you have to find out yourself which ports to open.
Mar 21, 2009 | Linksys WRT160N Wireless Router
Letting Ultra VNC go through a Dlink router to connect to a serve
You may have to define the VNC service under services then port forward that service on port 5900 to internal 5900.
Of if it has a Virtual Server option just forward port 5900 to 5900 and send it to the LAN IP Address of the computer you want to use.
If you need instuctions let me know and i'll post,
ta, HPC
Feb 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Port forward 5900
Jan 05, 2009 | Linksys Wireless-G WRT54GS Router...
Can't Remote Desktop from outside my local network
You'll just need to forward the port for remote desktop (RDP).
Nov 01, 2008 | Linksys Wireless-G WRTP54G Router
Linksys WRVS4400N Wireless Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
