Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Craftsman 139.53673SRT garage door opener. When I try to close door with remote or single push on doorbell control, the door reverses after 6-8 inches of travel - and big bulb flashes 10 times. I can close door by holding down on doorbell until door is all the way down. Door opens normally with remote or single push on the doorbell. Could this still be an RPM sensor problem?? Al
    President:
  • 3,197 Answers
When the main light flashes 10 times and the door reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor or wiring.
Posted on Aug 28, 2010
  • mulemanboss Aug 28, 2010
    Don - Thanks for your prompt response - should have mentioned that I do not have the infra red sensors on my door - only the pressure sensitive sensor which, I guess, is built into the circuit of the system. Do I need a new logic board?
    Al
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Chamberlin garage door opener has 3 terminals 1 2 3 2- photo eyes 1- pushbutton (doorbell type) 1-remote What is the correct connections?
1 WIRE WITH RED TRACE
2 WHITE WIRES WITH NO TRACE
3 WIRE WITH GRAY OR BLACK TRACE
ALSO THE WIRE TO THE WALL CONTROL MUST BE WIRED CORRECTLY - DOUBLE CHECK - IT TELLS YOU WHITE AND RED TRACE OR 1 & 2
YES THE POLARITY MATTERS ON THE WALL CONTROL EVEN IF IT LOOKS LIKE JUST A DOORBELL BUTTON.
HOPE THIS HELPS
Oct 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
370 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
