DG-HD 3800 instruction manual - Televison & Video
I need an instruction manual for my sigma lens
Not sure that the lenses come with an actual manual more of an instruction sheet. Google your camera make and model and select a site that reviews the lens. You may find the info you need.
Apr 12, 2015 | Sigma 70-300mm f4-5.6 APO DG Macro Lens...
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
I am looking for the manual to operate the Fuji PinePIx 3800 digital camera.
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Oct 04, 2010 | Fuji FinePix 3800 Digital Camera
I would like to have a manual for the sony str dg 510 reciever
http://www.docs.sony.com/release/STRDG510.pdf
Here's your manual. It has basic hook up instructions as well. If your looking for more extensive setups, post a comment listing all the products your putting together. make and model #'s and I can help you further. Hope this helps.
Sep 27, 2009 | Audio Players & Recorders
I need a manual for my lorance x38 HD fish
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man download a pdf version on this page
Apr 23, 2009 | Lowrance Lst 3800 In Dash Digital Depth...
Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Jan 28, 2009 | Fuji FinePix 3800 Digital Camera
Pt53tw53 panosonic
NUMBER OF FLASHES
POSSIBLE CIRCUIT
LOW D.C.
CONVERGENCE
HHS
5
IC4511
6
IC4518
IC4511 is on DG board. Asterisk indicates whole board is to be replaced. In schematic, labeling on IC4511 indicates it does some form of video processing. Manual instructs to add an "S" at end of board part number when ordering.
* DG-BOARD
TNP2AA126
PIP PROCESSING, SPLIT, SEARCH, FORMATS
Dec 01, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
