Question about LG WM-3677HW Front Load Washer / Dryer
LG WM3677HW Won't turn ON.
I started a load of laundry, and left the house. I came back to find the machine OFF. Pushing the power button will not turn on the machine. The electrical and water supplies to the machine are good.
I have some electronics training, so I took the machine apart (just a little). 115VAC is getting through the power cord, and through the "noise reducer" to the main circuit board. Without a better electrical diagram, I'm kind of at a loss from there. Is there something simple, like a fuse, that could cause this problem. I hope it isn't a dead circuit board. Any thoughts? Thanks.
  • Cyg241 May 07, 2008
    Thanks much. Wish I had this when I took the thing apart 2 days ago. Now my landlord is sending out a "professional". It seems that it is one of the boards. The electrical drawing in the document is on the back of the machine, but the troubleshooting flow chart was very helpful.
  • 487 Answers
Ok try this .
You say you know your way around electric. Here is the service manual incl drawings.
LINK
Posted on May 07, 2008
  • TIMOTHY DOBSON Jan 06, 2013
    your LINK shows Error 404 for the past few years. If you have the service manual for WM3677HW, please post. I may have posted one for WM3988HWA. slightly different. I cannot find any service manual for 3677HW
LG WM2277HB start button won't start cycle
Either the button is damaged or the switch it operates is malfunctioning.
Suggest you get a Technician to pop in and check it out while there is still plenty of life left in the machine!
Poppa
http://www.cdbaby.com/cd/poppamadison
Sep 23, 2012 | LG WM2277H Front Load Washer
LG WM3431 door won't unlock
did you unplug it,leave it unplugged for 5 minutes and plug it back in,if it's to hard to get to plug flip the breaker and leave the power off for 5 minutes or longer when you power it up again the door should unlock.here's a link to check hope it helps
https://www.google.com/search?q=lg+front+load+washer+how+to+manually+open+a+locked+door&oq=lg+front+load+washer+how+to+manually+open+a+locked+door&aqs=chrome..69i57.21935j0j8&sourceid=chrome&ie=UTF-8#kpvalbx=1
Dec 29, 2017 | LG WM3431 Front Load Washer / Dryer
LG WM3677HW all in one washer dryer water not draining and have cleaned out drain filter. what now?
i had the same problem turns out it was a pressure sensor. as water fills it the tub air gets pushed into this sensor to fill to the appropriate level or to drain.
Feb 23, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
We have a wm3677hw LG washer/dryer combo. it goes into the dry cycle and keeps adding water. what is the problem. we have cleaned all the internal tubes. checked the lower heating element and it is not...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Lg wm3677hw combo washer drain pump repair question
You replace the whole drain pump. Pretty easy to do from the opening in the bottom by resting the unit on its back. (Make sure you drain the unit completely) You should be able to get the drain pump (pt #4681EA2001D) from http://www.encompassparts.com/lgconsumer/ for less than $50 + s&h.
Aug 31, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water comes into machine when on dryer clothes tak forever to dry
This machine drys by intermittently spraying a mist of cold water into the warm, moisture laden air traveling in the tube at the back right side of the machine. The cooling of that air stream causes moisture to condense and join the added water, which is periodically pumped out the drain. It takes a long time, and the clothes are not as "dry" as you may be use to with a conventional dryer. Never try to dry more than a half tub of laundry. These machines are great if you have small amounts of laundry to do, have limited space, and / or do not have 240 volts, (or a gas supply) and cannot do an outside vent. Don't plan on doing more than two loads per day. (one in AM, one in PM) Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Jan 17, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM-3677HW Front Load Washer / Dryer Logo
630 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
