Question about Maytag EPIC MFW9700S Front Load Washer
Maytag Epic front load washer: Control lock on and won't reset.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Control lock light is on and nothing else will respond, and this continues even after unplugging/replugging. help!
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Maytag EPIC MFW9700S Front Load Washer
CONTROL PANEL LOCKED LIGHT ON, WASHER WONT WORK.TRIED UNPLUGGING TO RESET.
Press END OF CYCLE button and hold it for 10 seconds.. It will turn of the control lock feature..
Oct 06, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control locked
If you have a front loader then Press and hold the "end of cycle" button for 5-10 seconds and it will reset the child safety lock.
If the control locked light will not turn off, I recommend unplugging the washer for 5 minutes. Plug the unit back in and see if the controls will respond. If not, You could have a failed control console or a bad electronic control board in the washer.
Jun 19, 2010 | Maytag EPIC MFW9700S Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control locked
Check water pump filter and confirm motor still working?
May 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
My control locked button is lit on the control panel of my front loading Maytag Epic. Therefore, I cannot start a new load (which I just put in). The door easily opens and shuts as itnormally does. Any...
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. So, holding the "OFF" button will not clear it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, Kenmore Elite or Maytag Epic series FRONT LOADER, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 17, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag front loader washer, control lock light is on. how do i turn it off?
You have to hold down the lock button on the control panel for 3or 4 seconds it should turn off
Sep 12, 2009 | Maytag EPIC MFW9700S Front Load Washer
The ''control locked light is on'' how do i reset it
there is a button on the control panel, marked "control lock" hold for 3 secs to unlock, look closely its there
Nov 25, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
191 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
