Question about Yard Machines 21A240M000 Garden Tiller
I have a yard machines 31cc y28 17'' how do I fix the pull string it is pulled out fully
    President:
  • 1,033 Answers
Take the top cover off, You should then see 4 bolts around the engine cover, take these out and the cord head will come of,Depending on where the cord broke is the question of using the same cord, But if you're getting a new cord you will need to thread the cord into the eye for the cord, Tie a knot to prevent it pulling apart. then tie your handle on. After this you will wind the cord up tight on the pulley and a screw driver holding the pulley from moving while you put the cord and cap back on the engine, You can then start back installing the bolts and the other cover..
Posted on Aug 28, 2010
HOW TO REPLACE DUAL LINE ON GRASS TRIMMER
search google for "YARD MACHINE 31CC GAS TRIMMER Manual". the manual is there I have seen it. also check youtube.com
Hope this helps...
May 01, 2016 | Yard Machines Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
Pull string comes out 1/2 to 3/4 of the way and stops...doesnt crank the engine. What needs to be done?
pull off the recoil housing and see if the motor turns fully with out it if ok pull the rope off the engine does it pull all the way out
Mar 29, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I was using the lawn machine 31cc tiller today, the black handle with the string flew off (about 20 ft), I was able to re-thread the string back through the hole and handle but now I have no recoil. ...
You need to tension the spring also. On youtube donyboy73 has good video on how to do this and he shows you how to adjust string tension with the string still attached. I think it is in a video about Tecumseh engine/snowblower recoil starters. If you can not find it, let me know and I will write it out for you.
Sep 09, 2011 | Yard Machines Garden
MTD Yard Machine CD000147 6HP 21 inch ..The problem is "Cannot pull the starter string for start. The string or engine stuck to pull the starter. We didn't use it for the whole winter.
The operator presence bail must be in the run position to release the flywheel brake. If you can't pull the rope with the bail in the run position, your rope is fouled. You will have to remove the shroud and take it to a repair shop.
Apr 19, 2010 | Mtd 22" Yard Machine Push Mower
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Open Questions:
Yard Machines 21A240M000 Garden Tiller Logo
1,078 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
