Question about Speed Queen CES68AWF Dryer
I have a speedQueen gas dryer that does not heat clothes. Drum turns. I checked the flame which was fine and it heated when it was empty. I have been having an issue with a fuse that pops occasionally in that room. I reset the fuse and again, the dryer drum turns and there is a flame, but when I have clothes in no heat........Any ideas. I checked the hose and again when its empty, it heats just fine. Only when I put the wet clothes in does the no heat come into effect.
heatman101
  • 43501 Answers
SOURCE: Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
mrfixit3667
  • 262 Answers
SOURCE: Gas does not ignite.
you should first check your ignitor, then your thermal fuses and hi limits, then your coils.
Posted on May 25, 2010
  • 121 Answers
SOURCE: Drum will turn empty but will not turn with heavy
no, most likely, especially if it sounds right, it is a bad belt. The reason why i say if it sounds right is because the machine don't know the difference. if it was the motor you would hear a really loud hum before it stopped and then maybe it would start back up and hum some more. if your clothes are really heavy like dripping on your feet heavy. then you have a problem with your washer. Probably a transmission.
Posted on Jul 21, 2010
  • 205 Answers
SOURCE: gas dryer won't dry clothes.
Hello- You most likely need an ignitor or thermal fuse if you are getting no heat at all. Depending on you exact model and if you are electrically handy and have a multi-meter you can test these components and replace them. If you are at all uncomfortable have a Tech come out, they should have the parts on hand and it should be a fairly easy fix. Hope this helps, best regards.
Posted on Sep 27, 2010
heatman101
  • 43501 Answers
SOURCE: ignitor heats up,gas valvle doesnt
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 26, 2011
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
I have a speedqueen gas dryer model AGM499w iGNITER LIGHTS BUT NO FLAME
heatman101';
May 24, 2011 | Speed Queen AGS28AWF Gas Dryer
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
The Dryer is Dead. It will not make a sound when the start button is pushed
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or OK like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Be careful in using laundry products not to spill them on the exterior surface of any washer or dryer. Wipe up any spills promptly with a damp soft cloth or paper towel. Most exteriors are painted synthetic enamel, which can be damaged or removed by chlorine bleach, ammonia, solvents or other chemicals often used in laundering and stain removal. Do not use dryer top as a work-top for stain removal unless it is protected by a heavy plastic cover, or for rust removal. Use the sink instead and follow remover product label directions exactly, including flushing the sink with cold water.
Do not spray per-wash stain removers on clothing on top of the dryer unless the top is protected completely; this may corrode plastic control parts as well as paint.
Clean lint filter after each load for efficient drying. If the load is loaded with lint, clean the filter part-way through the drying cycle also. Clean out the exhaust vent system at least once a year, and be sure it is not clogged at any time. NEVER vent a dryer into the house; vent to the outside
If crayon gets into the dryer and melts onto the drum, remove as much as possible with non-flammable household cleaner. (READ LABEL TO BE SURE.) A flammable cleaner could cause a fire in the dryer. Apply cleaner to a sponge or cloth and the wipe interior. Do NOT spray or pour on the interior; it might get down inside the dryer. Wipe off with rags or paper towels. Then tumble old rags to remove any residue left, until no more comes off. A colored stain may remain on the drum.
If a drum is spotted by starched or tinted articles, wipe the interior with a cloth moistened with a diluted bleach solution. Use a sponge or clean cloth, dipped in suds, to remove the bleach solution from the drum. Rinse well and dry.
If the dryer is used to dry laundered clothing, such as children snow pants between outings, wipe the drum with suds and rinse. This will remove any dirt before clean laundry is placed into the machine.
Wipe the door opening occasionally. Clean the exterior with suds and rinse. To protect the finish, polish with an appliance wax.
A case of white clothes coming out of a dryer blue: New jeans had been washed and then dried in that dryer just before. Sometimes dye will come off new blue jeans and dry on the inside of the dryer drum, and then transfer to the next batch of wet clothes put inside. It's good to check the dryer drum after a load of brand new jeans. If it is dye coated, clean the inside with soapy water until no color comes off on the cleaning cloth. Wipe off all soapy residue with a clean wet cloth.
Check with your state or city to see if you need a permit to work on your gas dryer before doing any repairs. The first thing you need to do when your GE-HP gas dryer is not heating, is to check to see if your dryer ignite is glowing or not.
please comment on these solution by staying now helpful
If the ignite glows, the problem could be the gas valve, the coils or the gas supply to the dryer.
If the ignite doesn't glow, then you need to check the following parts.
The igniter:
The igniter is a resistor made of ceramic and other materials that will get red hot when electricity passes through it.
The job of the igniter is to open the contacts on the flame sensor and ignite the gas. A bad igniter could be the reason why your GE-HP gas dryer is not heating.
The flame sensor:
The flame sensor is located on the combustion chamber, the job of the flame sensor is to open the gas valve and shut off the igniter. A bad flame sensor will cause the dryer not to heat.
The timer:
The timer is a distribution center where the electricity is directed to the different electric parts in the dryer.
The mayor problem you will find inside of the timer are burnt contacts.
When the contacts are burnt, there is no way for the electricity to reach the intended parts. Contact B & A have to be close in order for the electricity to travel to the temperature switch.
The temperature switch:
This switch is another distribution control. It take electricity from the timer and send it to the selected parts on the thermostats. If your GE-HP dryer is not heating, this is one of the parts you need to check.
The thermostats:
There are three different thermostats in most dryers. From the temperature switch electricity has to pass trough the safety thermo left, the drum outlet thermostat, the control inlet thermostat, and to the heating elements.
A bad thermostat could be the reason why your GE-HP gas dryer is not heating.
The motor switch:
The motor switch has two contacts that allows the heating elements to be turned on, only when the motor is running..
Dec 21, 2010 | General Electric DBSR463GGWW Gas Dryer
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
Does not get hot
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energized. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Jan 11, 2010 | Whirlpool LGB6300 Gas Dryer
Gas dryer 4 yrs young and won't heat. Drum turns.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 04, 2009 | Televison & Video
My gas dryer puts burn marks on my clothes. I only use low heat
The flame is too high or the heat sheild is defective. The flame is too close to the drum!
Mar 26, 2009 | Frigidaire Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Speed Queen CES68AWF Dryer Logo
42 people viewed this question
Top Speed Queen Dryers Experts
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
