Question about Maytag MMV5156AAS Microwave Oven
Theres no power won t turn on is there a reset
  • Maytag Master
  • 17,129 Answers
Remove and keep of for about 10 minutes if there is no signs of life, then it can be that the power supply to the control panel has failed.
Usually this is a step down transformer fitted on to the board. so check fuse and see for primary winding failure.
If not the recitfier, regulator can be faulty or futher the microcontroller can be a suspect.
Posted on Aug 28, 2010
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Sharp R-1870F Microwave Won't turn on
Could be just a fuse but probably the diode pack or magnetron.
May 24, 2017 | Sharp R-1870 Convection/Microwave Oven
My Oster OM1201eovg microwave will turn on but it won't heat what I put in there. What's the problem?
Either the inverter which powers things or the Magnatron which in effect does the heating are bad.
If a fairly expensive unit it may be worth repair as these are of course two of the more expensive parts in the unit.
Sep 04, 2012 | Microwave Ovens
Microwave won't turn on
Depending on the make helps determine the problem, if there is no power it is more than likely the fuse is open.
Apr 09, 2012 | Microwave Ovens
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
Microwave won't turn off
Well first of all switch off your microwave oven from main plug and unplug the power cable from power switch. After 30 min. put the cable back to power plug and check you microwave again. If further you have the same issue then post the brand and the model number of your microwave for further assistance.
Good Luck
Nov 06, 2011 | Microwave Ovens
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
62 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
