Question about Saeco Caffe Charisma Espresso Machine
My machine has been sounding louder and louder during the dispensing process
My Saeco Caffe Charisma is about a year old. About a month ago the coffee was coming out slower. The process of dispennsing the coffee has been getting louder. I've turned down the grinder setting and lowered the amount of beans. Any ideas besides the expensive repair service center?
  • 40 Answers
Your grinder is probably due for cleaning. If in warrantee, it may be covered. If not, need to contact SAECO for an authroized
Service Center. Also note that if you use dark roasted beans ( which are oily) + you store beans in refrigerator/freezer, you will definitely have to clean the grinder more often. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
Grinder blocked Saeco Caffe Charisma
If the problem is only just stuck then you should try to rutn the gringing adjustment to more gross grinding and first try to remove all remain coffee beans from grinder, with the use of avacuum cleaner try to clean everything from the grinder beans and grined coffee. Then try to make a coffee if it continue to be stuck turn for more gross coffee grinding clean with vacuum and try again is the grinder is only stuck then this will work if after all these the grinder does not turn then you will need to remove it and also you might need to replace it.
May 10, 2012 | Saeco Caffe Charisma Espresso Machine
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Cafe Charisma
no! the max temp is pre set to about 90oC to 95oC on the p.c. board. any higher temp will cause the the coffee beans/grounds to burn, thus BAD TASTING coffee , according to most experts (barrista)
Feb 08, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Jan 31, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Caffe Charisma Espresso Machine Logo
166 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
