Question about Dryers
Fan stopped rotating a month ago and now it will not come on at all. Sounds like motor is on but fan is not spinning. fan is a year old and we paid $130.00 for it at Home Depot. Is there a warranty for replacement?
  • 377 Answers
Check with HD on the warranty. If not warranty, seems like the manifold/flywheel might have come loose or broken. This is a large circular rubber device that holds the blades to the motor shaft.
Posted on Aug 29, 2010
Why is my fan not spinning on start up?
You need to replace that fan motor, the bearings are shot for the shaft.
Oct 27, 2016 | Office Equipment & Supplies
Why doesn't my fan rotate anymore?
definitely sounds mechanical. try prying open the motor area and see if anything happens when you turn it on. i'm guessing it might be a short somewhere that's making the other parts have to compensate
also check into servos, relays, and whatnot
May 15, 2015 | Miscellaneous
I have what sounds like a squeaky bearing sound at any speed. Varies with RPM. Looking for likely culprits.
you're on the right track, removing the serpentine belt and manually rotating/ spinning the pulleys listening for a dragging, or grinding. If its very bad you may even see a outward movement. hope this helps!
Feb 04, 2015 | 2008 Ford Mustang
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Power light is on, water is up to fill line, dials are set to max humidity and fan speed, but fans do not spin. Tried to spin fans manually but they will not spin on their own. Left fan stopped spinning...
Do the motors feel warm-- maybe even HOT?-- Like they have electric current, but the bearings might be seizing up?
You mentioned one stopped spinning awhile ago--- and the other one was OK-
It sounds like the bearings are dry and worn on the fans-- (How old is the humidifier?)
The bearings CAN be cleaned up and lubricated, if you are into tearing a motor apart, and servicing the bearings-- Are you ready for that? You will have to remove the motors from their mounting, remove the fans, split the end bells, and clean and lubricate the bearings deep inside.
Let us know how much further you want to go-
Mack B
Jan 19, 2011 | Kenmore 14416 Humidifier
The dehumidifier's fan does not turn and makes a humming noise
first,make sure the fan blade hasn't gotten stuck on the shroud and cannot turn,then shut off machine and by-hand rotate fan and see if it spins to a stop after several rotations,if it stops quickly there is a bearing problem with the motor,this is normal after many years of service,then replace the motor
Jan 26, 2010 | Dehumidifiers
Compressor works but compressor fan does not
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Dave
Dec 07, 2009 | Heating & Cooling
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
99 people viewed this question
Top Dryers Experts
