Question about Frigidaire GLEQ2152ES Electric Dryer
Was working on Frigidaire electric dryer GLEQ2152ES for a customer with a complaint of no heat, tested heater element and it tested good, only one of the wires going into the heater element was getting 110, the other wasn't getting anything, traced the wire back to the relay on the board and assumed it was that relay, replaced the board and still didn't get 110 going to the black wire, yellow wire still had the 110. Also replaced the safety thermastat and the heater element, still didn't change anything, the only thing I didn't change was the thermal limiter, how would I have tested the limiter, or known if this was the problem. I gave the customer their money back as I'm just trying to build my own repair business and I'm just out a bunch of time and money, 1st time this ever happened, they are buying a new one and I'll be haunted for life if I can't figure out what the problem was??? HELP PLEASE.............. Thanks, Mark
  • Frigidaire Master
  • 7,482 Answers
Hi Mark...
You test your thermal limiter with an ohm meter just like you used with the coil. It should show continuity.
Did you check the voltage at the receptacle to be sure you were getting 220v from the breaker?
Also check the electric cord going to the machine to make sure you do not have a broken wire in it. Check it where it connects to the back of the machine.
I hope this was your problem solver...good luck
Rate me please
Posted on Aug 28, 2010
  • altonbaker19 Sep 13, 2010
    im going through same problem with this same dryer and did all the same stuff you did. rally frustrated with it!!
How to replace dryer heating element
Good Morning Friend,
I understand that you are looking for instructions on how to replace the heating element on your Frigidaire dryer, model# GLEQ2152ES, due to your appliance not heating. Typically this is not a do it yourself repair and there are no instruction manuals out there to aid with this repair. I suggest either contacting the manufacturer or your local authorized technician for further assistance. They will be able to better assist and point you in the right direction for repairing your dryer. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Drum sparking
Hi Keith, I am happy to assist you!
From what you have described it sounds like the heater on your Frigidaire dryer may possibly be loose. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to proceed further.
Dec 14, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Dryer heat not working
Without knowing your problem, I would guess that the heating element has burned out. This is a common issue with many dryers, regardless of brand.
The hearing element in a clothes dryer is like any other heating element, such as in a space heater, heat gun, or hair dryer. It is basically a continuous coil that is held in place by insulators, usually ceramic.
As the element ages, the coil becomes brittle and can often break. When a breakage occurs, the circuit is no longer complete and will not produce heat.
Replacing one is fairly simple.
  1. The first thing that you should do is unplug your dryer.
  2. Once unplugged, remove the exhaust duct.
  3. Use a screwdriver to remove the electric access panel in at the rear of the dryer.
  4. Locate and remove the heating element.
  5. Inspect the element for a break in the coil. The problem is not always obvious so it may be good to do a continuity test on it.
  6. Replace part if necessary. Elements will usually run $20 or so.
  7. Assemble in reverse order and test.
This website has some really great detailed step by step instructions on replacing a heater element.
Good luck.
Jan 11, 2013 | Frigidaire FFLE2022MW Electric...
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer, looks like the heating element is good. no heat, all else works fine
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have 75 volts ac at the heater element
Checkout the tip for the electric dryer...you have a problem with something cutting out the current before the element...probably the high limit ...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My front load dryer model number FEQ1442ESO is running but i dont have any heat. do you know what could be wrong
an internal thermostat called a snapstat and/or your heating element and/or your dryer ventmay not be working or needs cleaning. you need someone experienced in testing with an ohmmeter to test and get back to us.thanks karl
Dec 02, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Does not dry clothes, no hot air
This would be caused by a blown thermal fuse or a faulty heating element. Both components can be tested for continuity using a multimeter. A lack of continuity indicates a faulty component. The thermal fuse is about one inch long. It's located just inside the rear of the dryer and is usually attached to the exhaust duct. Hope this helped and best wishes.
Aug 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
97 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
