Question about Dryers
No electric flows to glow element on kenmore gas dryer 8798 0100 79801. there is continuity in glow element and fuse and flame detector.
  • ppatera Sep 12, 2010
    the glow element is the igniter i tested it for continuity ,it is good .there is no electric going to it to make it glow hot.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Sep 12, 2010
    Then trace the wires back and check the thermostat and the high limit...either of them can cut off the power to the ignitor...
Dryer Heats on low flame, No mater what setting its on...
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Mar 24, 2015 | Kenmore Dryers
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Jul 21, 2014 | Kenmore Dryers
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
Jun 14, 2014 | Kenmore 63942 Dryer
My Kenmore elite gas dryer sometimes starts and sometimes doesnt ?
Thermal Fuse
Air Flow and Heat
Warning
Jun 02, 2014 | Kenmore 74892 Gas Dryer
Gas dryer not produce high heat
Thermal Fuse
Air Flow and Heat
Warning
May 14, 2014 | Kenmore 62802 Electric Dryer
Dryers Logo
79 people viewed this question
Top Dryers Experts
