Question about Zyxel ZyAIR G-570S - Wireless access point - 802.11b, 802.11g, 802.11 Super G (ZY-G570S)
I reset my acces point modem now i canot find
Unable to access settings of d-link modem dsl-2750u
Your Connectivity may be on Wifi or Lan, ping the gateway and verify gateway IP is up and running if not then try to manually assign the IP to the system and try ping and if there is any proxy Please also remove the proxy from the internet settting and if still problem.Then reset the modem and then also set the IP of your system 192.168.1.2 and access the by default IP 192.168.1.1 and configure the acces point
Nov 27, 2013 | D-Link Computers & Internet
Model cherry mobiles80 canot acces to inernet how to acces
Chinese mobiles are not recognized by your network provider. Ask customer care of your network provider if it supports Cherry.
Jul 04, 2011 | Cell Phones
Access to internet through the modem works fine. As soon as I hook up the router, no access. I have booted up the modem, the router, and the PC with no luck. I have pressed in the reset button on the...
you can not acces the internet if you reset the modem and the router. once you reset the router it set back to original factory setting. theres a certain configuration for the modem the router especially for the ip address. you have to get in touch w/ your internet service provider for the modem and router configuration.
Jun 07, 2010 | Computers & Internet
New modem & nowI cannot acces the internet or email. I got a new
Reset your router and reconfigure your router as per the new modem settings or else you can contact your isp after the router reset.
Jun 03, 2010 | Linksys Wireless-G WRT54G Router
I canot acces bios utility setup i forget my password for bios My laptop model Acer TravelMate 2410
to reset the bios password go to acer service center and tell them that u have forgotten ur password and ask them to reset it.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
I have the mc 70 how do i get started if i wanted to send my orders using wifi
i thank that you have to configure you acces point first, and configure also your unit to communicate with your acces point in setting( ip adress,subnet mask,ssid,keys...) and and connect your acces point to your system( switch,modem ,,,)
Feb 03, 2010 | Symbol MC70
No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
Aug 29, 2008 | Trendware TEW-630APB (TEW630APB)
Canot access ADMIN screen
Look on the modem for a reset button, usually one you will need a paper-clip to press. Many modems will have this (not familiar with yours) and will completely reset your modem (IP's, passwords etc)
Jun 06, 2008 | Linksys Wireless-G WRT54G Router
I want to use my WAP to share my internet connection.
i have motorola wa849g.i reset now i want to cofigure this i open explorer put 192.168.10.1 didnot open show page canot open
May 22, 2008 | Arris WA840G 802.11g/b (49832000100)...
Cannot connect onto the 192.168.0.1
On the back of the unit you should see a small hole to reset the router. once it is re-set try logging in again at 192.168.0.1
Apr 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Zyxel ZyAIR G-570S - Wireless access point - 802.11b, 802.11g, 802.11 Super G (ZY-G570S) Logo
133 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
