Question about A.O. Smith SQ1102 Pool Pump Motor
What is the correct position for the cooling fan on A O smith pool pump motor QC1102. I have a repaired motor and it runs really hot, I suspect the fan is backwards or on the shaft incorrectly. thanks, bob
c17hydro
  • 2984 Answers
SOURCE: Where can I find a replace thermal overload protector?
http://www.mypool.com/Products/Catalog/mo.asp for the capacitor.
See if there is another part number for that breaker (CET51 ABM).
Posted on Mar 10, 2009
  • 832 Answers
SOURCE: need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Posted on Oct 25, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Pool Pump does not Prime.
CRAIG .. IF ITS A STA RITE PUMP DURA GLASS YA GET IT FIXED ! SHOULD COST ABOUT 75.00 SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY . ASK IF HE DOES FREE MOTOR TESTING
Posted on Jun 30, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: I have an AO Smith SQ1102 pool motor that stopped
no. it sounds like its too late for your motor , no need for a pool pump motor repair kit ,there is one on ebay . but it sounds like your motor is toast if it blowing the breaker... hey i could be wrong . look for a shop that has free pool pump motor testing .use your zip code in your search..
as far as using the bearings off them threw bolt motors. do what ya got to do, but you might find that the front bearing is a bigger bearing .. i charge 85.00 to rebuild a 2.. but you must catch them befor its too late 2hp new = big $$$
best of luck .. and if'n i was any help ? push on them thumbs up to vote ... thanks jay..oh PRIME THAT PUMP !
Posted on Jul 31, 2010
junk9
  • 150 Answers
SOURCE: I have a A O Smith SN 1152 pool pump. The motor
Remove the 4 fasteners that hold the pump head onto the motor and try to turn the motor shaft by hand. If it turns freely, apply power and see what happens. If it turns Ok, then your problem is the pump head not the motor. If the motor does not turn by hand then it needs to be replaced. If it turns by hand but not when power is applied, you may get away with replacing the bearing in it.
Posted on Nov 18, 2010
New ao smith pool pump motor keeps tripping out under load
check the breaker might be weak possibly from previous pump motor also if it was hooked up incorrectly at first might have done damage to motor windings
Apr 17, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Why is new ao smith pump getting hot
Most motors are warm to hot when running.
Is it getting so hot that the thermal overload is turning it off? If so the pump should restart once it cools down.
If this is a new motor on an old pump (replacement) it is likely to be:
1.) Incorrect or loose wire connections.
2.) Low voltage supply (frequently caused by undersized wire).
3.) Lack of fresh air supply to motor due to clogged vents.
4.) Incorrect amperage of replacement motor.
Jul 25, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I have a Cantar pool pump and it has been running hot and has a vibratinf sound other than that it works ok, What could cause the vibrating and the pump being hot?
MOTOR HAS BAD END BELL, YOU NEED TO GET IT TO A SHOP ASAP FOR TESTING. HERE IS HOW TO REMOVE MOST PUMPS CLICK HERE
THIS WAS A SUMMERY AS MY COMPUTER REBOOTED. JAY OH THE COST TO REPAIR THAT SHOULD BE AROUND 75.00 WITH SHAFT SEAL
Jun 22, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
May 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
My power cord was cut, positioning for new positive and ground and negative wires are needed
If you're running 120v, the hot lead goes on the brass colored terminal and the silver is the nuetral and the green is ground.
for 240v. you'll have a red hot and a black hot... and then a white neutral and a ground as well. Ground goes to a screw terminal on the motor housing,
Aug 04, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool won't drain
must replace motor the cooling fan is damage and the motor is over heating whrn the motor coll down it will start again
Apr 21, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
A.O. Smith SQ1102 Pool Pump Motor Logo
274 people viewed this question
Top A.O. Smith Plumbing Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Gil Shultz
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
