Question about Health & Beauty
The startup division made 80% of 1/2 of the established division. The startup division?s growth was 1/3 greater than the established division?s. If the divisions made $280,000 combined, how much did the startup division make?
$105,000.00
Posted on Jul 03, 2015
When is the best time to prune rose plant
I like to prune mine after every blooming, but I live in a climate where it blooms year round. I am not sure where you live, but if you have a cold winter, prune them heavily just before the spring growth season. Depending on where you live that could be anytime between January and April. If these are older established roses. Prune them back after each blooming during the growing season. You will get a lot of flowering this way.
Oct 07, 2016 | Garden
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
Can you explain the basic algebra symbols
+ symbol means to add together, - symbol means to subtract one from the other, x means to multiply each, / means to divide.
Jan 29, 2015 | Super Tutor Pre Algebra (ESDPALG)
How to prune
little light on the details; but if you're talking trees, dead stuff first.
Then decide what you are needing to do.
To thin ... remove up to half of the limbs back to the trunk. Don't just shorten them or you'll get thicker outer branches. You could remove outer branch back to a division pointing upward.
To shape ... cut outer growth back to a shorter branch going in the right direction.
Don't remove more than a third each year until it looks right to you.
Aug 18, 2014 | Garden
What are the prime numbers
A prime number is a whole number greater than one divisible only by one and itself. See http://en.wikipedia.org/wiki/Prime_number
May 09, 2014 | Computers & Internet
What is an
"Agro-Lite" is a minor variant of the wide spectrum Gro-Lux made by Phillips. The tube resulted with a 10 percent greater growth in comparison to other wide spectrum plant lights.
Aug 21, 2012 | Fish
Ln(300.9/203.3) all over or divided by 37. The answer is 0.011. How do I enter this?
  1. Press the key marked [LN],
  2. If the calculator suppliies a left parenthesis (, proceed to enter the ratio 300.9/203.3.
  3. But if the calculator does not insert a ( after LN, insert one and then enter the ratio 300.9/203.3
  4. Close argument by pressing the ) parenthesis key.
  5. Press the division key, followed by 37.
  6. Press the =/EXE key.
  7. The result should be 0.010597169 or about 0.011
Jul 16, 2012 | Sharp ELW535 Calculator
Ive.comprogram to find the number of and sum of all integers greater than 40 and less than 250 that are divisible by 5 in java coding ????
I'm not going to do your homework for you, but here's a hint. You can use the Java modulus operator % to find if a number is divisible by 5. It provides the remainder after dividing, which will be zero if the number is divisible by 5. Here's a pseudocode example:
if ( (testNumber % 5) == 0)
numberIsDivisibleBy5 = true
else
numberIsDivisibleBy5 = false
You'll need to provide the rest of the work to put this test into a loop that goes from >40 to <250, checking each number and doing whatever you are supposed to (print a message, probably) when you find one divisible by 5.
Good luck and thanks for using Fixya.
Jan 26, 2011 | Computers & Internet
Health & Beauty Logo
281 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
