Question about GE Spacemaker JVM1640SJ Microwave Oven
My ge is sparking inside. There's a screw not covered and I covered it and still sparked.
  • GE Master
  • 17,130 Answers
I think the magnetron is leaking with traces of open metal exposed out. It will be better to clean the cabin throughly and make sure that there aren't any exposed parts.
If the sparks are still coming in then remove tthe magnetron and check for signs of spark marks on it , if so it must be replaced.
Make sure that the wiring is intact and there is no foreign particles stuck within the magnetron.
Posted on Aug 28, 2010
My GE Profile Advantium 120 microwave sparks when I try to sterlize a kitchen sponge
Wayne,
If your sponge has any metal in it, that would be the cause of the sparking. The only other thing that could cause sparks is grease built up behind the wave guide cover or the magnetron is going bad.
Jun 13, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
GE JE2160 31/2 years when it is turned on sparks fly from the cover plate located on the right inner wall. If it can be repaired is there an estimate of cost. Thanks gm.eiland@gmail.com
All you need is a new WaveGuide Cover. It is fitted with usually a screw or plastic clip and is fitted from inside of the cavity, where you place your food to be cooked. No taking anything to bits, just the cover.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | GE JE2160 Microwave Oven
I have a GE spacemaker. It releases electric volts when is turned on . Needs to be changed or can be repaired?
Do you mean "sparks" inside the oven cavity when it is operating ?
If so, check for grease spots on the wave guide cover or scratches on the oven liner. Scratches can be touched up with touch up paint and wave guide cover`s can be replaced.
Hope that help`s, good luck.
macmarkus :)
Feb 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Sparks inside the microwave
remove the round button(s) and remove the cover..clean thoroughly and replace anything thats burnt, if metal clean and paint touchup
Jun 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave -crackles and sparks as if metal inside
The problem you are having is that the magnetron that does the heating is shorting out and it needs to be replaced before it damages the inside covering of the microwave. www.mwoparts.com is a good source for magnetrons or other similar sites. To replace is easy enough. Taking the cover off with the power off, you will find it behind and on the top right side of the control panel. It is held in place normally with just 4 screws and two wires with terminals attached to it. So removing and replacing is pretty straightforward. Just be sure all the power is off until you have everything back in place. Good luck.
Jan 23, 2009 | GE JES738 Microwave Oven
Microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
104 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
