Question about Crosley Dryers
MY CROSLEY DRYER WILL NOT COME ON. IT WAS WORKING FINE AND NOW WHEN I PUSH THE START BUTTON NOTHING HAPPENS.
  • Crosley Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
5 Suggested Answers
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
  • 278 Answers
SOURCE: My dryer (frigidaire stackable washer/dryer) just
Howdy: The circuit breaker could have popped in the motor. Maybe the selector on/off switch has gone south. Will need a AC meter to check voltages from switch to motor. Doug
Posted on Dec 09, 2009
SOURCE: Kenmore 600 Series gas dryer
trigger broken dryer will not turn on. I need a replacement. Where can I buy this part.
Posted on Mar 27, 2010
kvhappliance
  • 218 Answers
SOURCE: My GGQ 9800 gas dryer won't start. It was working
Things to check first on a no start dryer.
Check for power at outlet.
Inspect power cord.
When you try to turn it on do you hear anything?
Check the door switch(does it click when pressed in?)
The next item to check and most likely replace on a completely dead dryer with power and a good door switch would be the thermal fuse located inside the cabinet.
Please let me know if I can help with anything else
Posted on Apr 08, 2010
Crosley gas dryer will not work
Probably caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
May 30, 2014 | Crosley Dryers
Dryer will not start when On button is pushed to start.
Check out the door switch. Push it in as far as you can by hand and hold then hhave someone try and start it. If that works you need a new door switch
Jun 10, 2010 | Crosley CDE6000 Electric Dryer
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
Nov 02, 2008 | Dryers
Crosley dryer
right the part that is faulty is a silver tube which is fastened to the motor take it of making sure you have done a diagram of the wiring replace it once replaced the dryer will work fine common fault on these dryers its just wear and tear m8
Nov 17, 2007 | Crosley CDE6000 Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
148 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
