Question about Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices
Remote control works the light on my Hunter ceiling fan but blades do not move
  • 377 Answers
Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
Posted on Aug 29, 2010
How do I repair a Hunter Ceiling Fan thats blades won't spin?
The remote receiver could have failed partially so only light control works.
May 26, 2015 | Hunter Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
The remote control works other than changing the direction of the blade. how do i manually change blade direction?
Look on the side of the Fan above the light fixture there is a little black switch you just need to switch it, make sure the fan is off before switching it.
Jan 11, 2010 | Hunter 52" Ceiling Fan With Light And...
New hunter fan makes about 5 clicks per revolution at any speed (5 bladed fan), Worse in one direction. No chains, wires in blades. Moving the housing by pushing on the light makes no change. Whats up?
I would pull it apart if necessary (depends on the model) and look for a small piece of packaging material in the air vents on the top of the motor. Good luck.
Jan 03, 2010 | Hunter 52" Ceiling Fan With Light And...
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hunter "Lexus" Traditional 52" Ceiling Fan "Black" w/ three Blade Choices Logo
137 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
