Question about Whirlpool 25.3 cu. ft. / 716 liter Upright Freezer EV250NXKQ
Frost on the inside of freezer and on the door on the inside.
  • 70 Answers
Door/Frame heater not working.
Posted on Aug 28, 2010
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
How do I know if the door seal on my up-right freezer needs to be replaced?
you could just look at it and see if there is any damage, but most likely the unit is just not level, and the door isent closing correctly , of corse if getting frost inside the seal is not working correctly look for damage or door misalinement
Jul 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
There is frost in the freezer. I thought it was frostless.
If you live in a humid environment its the water vapor in the air that is turning to frost in your freezer. Every time you open the door you are exchanging the cold dry air in your freezer for the humid air on the outside, and when you shut the door closed its this humid air that turns to frost inside the freezer. If its building up frost faster than normal you might have a door gasket that is leaking the cold air outside thus letting the humid air in, which is turning to frost. Check that your door is aligned properly and that the gasket is secure on the freezer door.
Hope this helps explain it.
Feb 01, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice and frost
Excess frost especially near the door is caused by door gaskets being bad. The gasket should hold a dollar bill snug.
Another possibility is auto defrost failure. - Remove the cover on the rear inside the freezer to see if the coils are heavily iced.
Aug 13, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My woods upright freezer keeps frosting up at the top with several inches of frost. It is a manual defrost freezer. Any suggestions?
check your door seal, by closing the door on a strip of newspaper all round the seal. this fault is usually air getting inside the freezer, it rises to the top making thick ice or snow.
Dec 17, 2008 | Woods Upright Freezer MU07W
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Whirlpool 25.3 cu. ft. / 716 liter Upright Freezer EV250NXKQ Logo
46 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
