Question about KitchenAid Dishwashers
Dishwasher modle #kud10i1bl2 green lights blinking on panel how do you reset?
  • panaroo Aug 28, 2010
    it did not work there is nohigh heat button
    green light is flashing tried buton sequence of temp/dry temp/dry did not work
  • KitchenAid Master
  • 43,501 Answers
The first thing to do is to turn the power off for a few minutes and then turn it on again...
If that doesnot work then the brain module has gone bad...
You can easily replace that and buy it online.
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
  • KitchenAid Master
  • 12,061 Answers
To Reset a Dishwasher one MUST remove from the mains Power for a few minutes and then reconnect.
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/dish/ch01.htm
Above is a online manual to assist in troubleshooting your issue if the below "Fix" doesn't apply, it often does..
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle.This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • 3 more comments
  • Rylee Smith
    Rylee Smith Aug 28, 2010
    OK, then press these buttons in sequence:
    High Temp. Scrub-Energy saver dry-high temp. scrub-energy saver dry.
    still ng any other ideas?
  • Rylee Smith
    What all buttons are there?
    heavy normal rinse high temp scrub energy saver dry start cancel
  • Rylee Smith
    Try to unplug the dishwasher and then try, if still it wont work then you'll have to replace the panel.
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
No power to danby portable dishwasher
If the dishwasher is new, why not get it repaired under warranty?
Dec 07, 2013 | Danby DDW1899WP Portable Dishwashers
Blinking Green Light After Strong Smell From Vent
It's either a fault with the control panel or the overheat thermostat. Check the electronics for broken solder joints.
Mar 12, 2012 | Kenmore 665
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
Dishwasher won't start and the green 'clean light' is blinking
your computer has detected a problem , most likely with the water heating. its locked up. Try pushing the high tem wash buton and then the energy saver button , push them back and fourth a few times(some modles its 2 other buttons) This should actavate a service check cycle where all the lights go on. Let it do its thing, and cancle after a few mins. if it locks up again you need service.
Dec 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
In sink erator dishwasher (older modle)
bottom panel loose on one side. cannot push it back in place.
Sep 08, 2008 | Servis 23 in. M4306 Free-standing...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
