Question about Geovision GV-800-16 Video Capture
We have a geovision 800 video system. THe camera have stopped recording and read lost live video. THe power supply is fine. Someone suggested to uninstall and reinstall the camera drivers, but I do not know how to do this and I am not sure where the software for this is. We had them installed 6 years ago and the man who installed it originally will not return my calls.
  • 10,421 Answers
I have gv 800 card using V8.5 software, i have five cameras connected but it only displays 4
This is not a big issue u ant watch 5th camera coz u had stopped other 122 cameras from working in GV eries you are allowed to stop remaining cameras from working to avoid video lost beep and video lost screen you can again start remaining cameras from here:in main menu (configure) 2nd option from top CAMERA/AUDIO INTALL ===> click on activate ===> activate the cameras as muich you want hope my post helped u
Dec 28, 2011 | Geovision GV-800-16 Video Capture
"Lost Video" error
Which version of the card are you using, BNC or D type?
Remember: GV-800 is currently not compatible with VIA series and ATI series chipset motherboards.
I know Dell uses mostly Intel chipset, but just in case, check with your motherboard to see if you don't have either ATI or VIA; specially since you already have the nVidia.
Try going to the BIOS on your PC and set the 'Primary Display' to PCI instead of the built-in chip.
If you have more information, please let us know. We can help you better!
Feb 01, 2008 | Geovision GV-800-16 Video Capture
I have a Geovision GV800 8.3.2, 16 channels and have 4 cameras installed. I tried to add 3 more cameras but they don't appear on screen, just on the Camera Record Setting, where the recording is ok. I've...
Hello
Have you tried at "Camera/Audio Instal" Menu?
Click the Configure button and select Camera / Audio Install to bring up the dialog box:
Click the Activate button and specify the cameras to be viewed
Hope that help.
Jan 09, 2011 | Geovision GV-800-16 Video Capture
On all cameras it says lost video
I assume you have multiple camera's and have checked that at lest one has power :-)
If so, most likely the PC has lost the cards License Key .. try uninstalling the camera drivers & re-installing.
Aug 22, 2010 | Geovision GV-800-16 Video Capture
I have losted video for no reason? was working fine
What kind of video card? What kind of monitor? What OS? What application? Is the video card correctly installed, both physically and software-wise? It is seldom that there is "no reason" when video stops working.
Sep 15, 2009 | Geovision GV-800-16 Video Capture
Cant view vedio log on GeoVision GV-600
Okay - try going into the software directory and delete the files maked .db there should be one for each camera. Then start the software and try it again.
May 14, 2009 | Geovision GV-800-16 Video Capture
PC w/Geovision 650 (800S) Card reboots but safe mode fine
Sound like a bad PV800 Card send to GeoVision to Fix
Nov 21, 2008 | Geovision GV-800-16 Video Capture
Gv-800
This problem could be because of the GV card version not compitable with GV main systems software you install please check the hardware version of the GV card and compare for compatibility. East way out downgrade to lower version of software. for example if you have version 8.1 install then install version 7.0 or something like that.
Aug 27, 2008 | Geovision GV-800-16 Video Capture
Geovision GV 800 video lost
Uninstall and re-install the drivers first. Let me know what that does.
Thanks,
Lee
Jun 20, 2008 | Geovision GV-800-16 Video Capture
Error message saying video lost and not recording
There are several possible issues at play whenever the lost video message appears.
First, have cameras lost power? If you powered cameras through a central power source, inspect it and verify it is working
If you powered cameras through a plug in transformer, touch it, if warm it is working
Next touch the cameras, are they warm? If so, they have power.
Once you have determined cameras have power, disconnect power for several minutes. Turn power back on, if cameras respond and send video, your cameras have likely suffered damage from a power surge and are near failure.
If you have access to a small tv with an RCA video in jack, you
can test this by leaving the camera powered, run a short length of cable from the tv to the camera. We use hand held mini monitors to test this, but they are pricey,
It is most likely that have power surge damage and the cameras need to be replaced
Oct 25, 2007 | Geovision GV-650 BNC (GV6504) Video...
Geovision GV-800-16 Video Capture Logo
222 people viewed this question
Top Geovision Televison & Video Experts
Mark Magill
Mark Magill
U-Spy Store DBA Pro...
Level 1 Expert
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
