I HAVE A RCA UNIVERSAL REMOTE MODEL RCR312WR WITH A ELEMENT BRAND TV. WHAT IS THE CODE I WOULD USE TO PROGRAM THE TV?
  • 51 Answers
From everything I can find it doesn't appear that your remote has a code for Element. I did find the following that may apply to your remote. Give it a try.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Aug 28, 2010
Iview 2600 hd code for a RCA universal remote
There is no setup code to this device with Iview. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 15, 2014 | Universal Remote Control Televison & Video
Sansui code list
2968,2927,2922,9217. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electro-medical.blogspot.com/
Dec 31, 2013 | RCA Remote Control RCR312WR p/n:RCR312WR
Need tv code for emerson tv model#EWF2006 using RCA remote model#RCR312WR
These are the setup codes for Emerson TV with this remote control.
10017, 10154, 10451, 10236, 10463, 10180, 10178, 10171, 11394, 11963
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  5. If you want more details, check this.
Dec 26, 2012 | RCA RCR312W Remote Control
What is the rca universal remote code for an element tv
Element is not listed to any RCA universal remotes.
May 28, 2012 | Televison & Video
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
RCA REMOTE RCR312WR CODES FOR PHILLIPS TV
Hello
Five digit universal remote codes for Philips TV with RCA RCR321W are:
11454, 10054, 10690, 11744, 11867
Four digit universal remote codes for Philips TV are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Direct Code Entry
May 31, 2011 | Televison & Video
I am trying to program my RCA Universal Remote (Model #RCR312WR) for an old Panasonic TV (Model #PVC2060) with built in VCR. I need to find the TV and VCR code for it. Thank you.
Try 003, 054, 055, 062, 070, 148, 149, 170 or 171. They seem to be consistent numbers for the Panasonic TV's.
You might have to enter a different code for the VCR.
Try 246, 285, 334, 340, 350, 363, 373 or 374.
I couldn't find any codes in my library for a TV/VCR combination so the remote might have to be coded separately for each component.
Hope this helps
Oct 28, 2010 | RCA Universal Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
640 people viewed this question
Top Televison & Video Experts
Electro Med Services...
