Question about Senco Tools & Hardware - Others
I just bought a new Senco Nail gun "Washer Firing Valve" Part LB3500 but can't figure how to get it into the groove. Do I need to heat it in hot water so it will "give" a little allowing me to "stretch" it a bit or is there another trick?
    President:
  • Senco Master
  • 1,383 Answers
I use a heat gun similar to hair dryer and get it pretty warm. The part is pretty tough and can be forced on but better to take your time and apply heat. Good luck with your repair
Posted on Aug 29, 2010
Testimonial: "Thank you very much for the "secret". I really appreciate you taking the time to respond to my inquiry. Buz"
  • 2 more comments
  • cab001 Nov 22, 2010
    I used your hot water method and it worked for me. I boiled water in a glass in the microwave and dropped the washer in the boiling water. Got the wife to help and used two small screw drivers to walk the washer around the groove. I have a heat gun but was fearful of over heating. The boiling water keep the temperature at max. 212 degrees which was enough to make it flexible.
    Charlie
  • John Trevino Nov 22, 2010
    Good job and its great to have an extra pair of hands helping on repair projects. We do use hot water to install hard rubber wheels onto large rims for walk behind mowers. We use a large pot similar to those used for frying turkeys. As you feared, hot air does not heat evenly over large surface. Rubber parts can not take much abuse and will break using hot air. Have a great thanksgiving.
    Check out this Youtube video on tearing down a Senco SN 4 nail gun to replace o-rings. There is a No 1 video also.
    http://www.youtube.com/watch?v=wQP8lHMVm...
    Charlie
    The guy on the video must be a pro working on air tools. Notice the oring measuring cone in the background. He most likely does not use factory orings instead relying on universal orings sold thru bearing houses. This is a good way to save money and gives the ability to slightly oversize the oring when possible/needed. Good video thanks!
Framing air nailgun Senco firing valve part question.
The spring is necessary for the head to reset - check your reassembly to make sure the parts are in the proper order and direction - make sure the piston stop in the firing valve is snapped into the head before you reassemble the gun - the head valve shouldn't fall out when you open the head.
Aug 25, 2016 | Senco FramePro 602 Full Round Head...
My senco sfn1 will not fire a nail not enough air?
Sfn1 is an oilless nailer. It needs about 100psi for full power. If oil has been used in the gun or if oil is leaking out of compessor and making its way into the gun, the rubber firing valve could swell preventing it from working correctly. The firing valve sits on top of cylinder (black plastic). If the driver is bent or piston fits too tight in the cylinder you will have similar problem. The piston/driver should move easily down cylinder (but not slip down under its own weight). Finally, the nail will not be driven all the way in if the tip if the driver has broken off. Good luck with your repair.
Mar 17, 2013 | Senco Air Tools & Compressors
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
Senco nail gun sfn30 is only firing every second nail in
You have damaged o-rings in the gun. Remove the head cap & valve assembly, remove the ring on top of the cylinder, remove the cylinder & piston. The cylinder is in tight so work it out carefully. Check the condition of the following: a split flat ring with a rubber o-ring under it on the top of the piston and two o-rings on the outside of the cylinder. If these are damaged air will leak around the piston instead of pushing it back up. The inside of the gun should be clean with a light coat of oil on everything if you are oiling it properly before use. Dirt in the gun means the gun is being laid on the ground without the air hose attached. Dry innards means no or not enough oil is being put in the gun before use. Oil pooled in the bottom of the gun means too much oil is being used. Senco doesn't make a rebuild kit for this gun, you'll have to go to the Senco website http://www.senco.com/ or other website like http://www.ereplacementparts.com to get a parts breakdown of your gun and order the o-rings (any part beginning with LB) individually. If you replace one, replace all of them and grease them up liberally when reassembling the gun.
Jan 29, 2012 | Senco Tools & Hardware - Others
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
I just rebuilt my Senco SN4 nail gun because it leaked air.
I think that you are referring to the firing valve and no it should not be split. I suggest going to Senco.com and typing in your model number fora breakdown for this tool. They offer different kits for various failures. Let me know if you need more help
Nov 23, 2009 | Tools & Hardware - Others
Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Jan 01, 2009 | Tools & Hardware - Others
SENCO SN-IV LB3500 Seal leaks air
The old seal was origionally the same as the new one, a white nylon, however over time the seal breaks down and looks like hard wax. The new seal may be installed by heating with hot air gun till plyable and gently streach over lip. While the gun is open, lube with nail gun oil. the piston should not slide down the cylinder under its own weight, if it does, replace the piston oring. Diagram available at senco.com
Nov 25, 2008 | Senco Air Tools & Compressors
Tools & Hardware - Others Logo
276 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
