Question about Petzl E Lite Headlamp Fall 09
I have a Petzl e lite headlamp and I can not unlock it. How do I get it out of the lock position?
2 Suggested Answers
  • 121 Answers
SOURCE: how to replace halogen bulb in petzl duo headlamp
Easy enough. The grey rippled rubber ring around the glass is threaded. Grab it good and tight and twist anti clockwise and it unwinds like a tank track..
Hope this helps...
Posted on Oct 09, 2009
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
Led light doesn't work
replace led light it went bad.
Feb 27, 2011 | Petzl Myolite 3 Headlamp
Petzl tikka plus torch repair
I understood that fixya was free from reading the word free all over the place. I wasted my time filling in the form to find out it was not free, but only 7 days free trial but you needed credit card details before. I will not be the first to write this and am tired of being told things are free when they are not. Do not mislead people.
Jan 05, 2010 | Petzl Tikka Plus
Facewest quiz
I believe you are looking at power settings, range compairson
Nov 11, 2009 | Petzl Tikka Plus
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    How to replace halogen bulb in petzl duo headlamp
    Hope this helps...
    Sep 22, 2009 | Petzl Replacement Halogen Bulb for Duo
    Minimag LED shuts off
    First question is what type of batteries have you been using.. A fault was found by Petzl a last year that identified a problem with using certain rechargeable batteries or lithium batteries in LED lights. The problem was that the batteries have a higher output than normal batteries and the heat created was damaging the LED's, shortening their life and in a couple of cases causing burning. Petzl have fixed the problem in their models and sent out warnings to outdoor stores to warn of the problem but I don't think that has spread too far across the industry..
    Hope this helps..
    Jul 25, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
    Petzl Tikka Plus Headlamp has a short and is eating batteries
    There's really not much that's serviceable in these things. Try cleaning all the terminals again but this time use VINEGAR instead of alcohol which does not neutralize the corrosion as vinegar does. Just dip a q-tip in the vinegar and swab it on the terminals, then with a dry one, swab up the excess. Then install all NEW batteries, do not mix old ones with new ones as the new ones cannot make the old ones work any better than they are used. If they still don't work, welome to the world of cheap products that are intended to be tossed when they quit functioning. Good luck. :)
    Apr 19, 2009 | Petzl Tikka Plus
    I need to disassemble Petzl Myo 3 - snapped cable
    i also have the same problem can you please give me instructions on how to disassemble it? thanks!
    Apr 10, 2009 | Petzl Myo 3 Handsfree Headlamps
    Petzl E Lite Headlamp Fall 09 Logo
    202 people viewed this question
    Top Petzl Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
